Update #3285.
Update #3285.
Update #3285.
system. Since all content of
makes no sense to keep it.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #2408.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3387.
Update #3285.
Update #3285.
Update #3285.
upgrade to that version.
Close #3387.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
* bsps/shared/cache
Update #3285.
line option.
may suppress warnings.
erc32, imx, qoriq, etc.
* cpukit/include
* cpukit/libnetworking
* bsps/include
* bsps/@RTEMS_CPU@/include
order.
Update #3254.
This is necessary to pick up mandatory flags provided by the build
system.
Update #3254.
Update #3254.
EXTRA_DIST += foobar
in fragments.
Update #3254.
Update #3254.
Updates #3520.
This patch removes the non-standard -qclock option which defines
_SYS_CLOCK_FREQUENCY. If actually used, this can be achieved by
providing ld options via the linking invocation of GCC.
Updates #3520.
Updates #3250.
maintain.
Update #3254.
BSP_PRESS_KEY_FOR_RESET=0
BSP_RESET_BOARD_AT_EXIT=1
BSP_PRINT_EXCEPTION_CONTEXT=1
Update #3239.
Update #2695.
Import the <arpa/inet.h> from current FreeBSD. Necessary due to changes
in <netinet/in.h>. Remove BSD hack from <arpa/inet.h>.
Clean up problems with htonl(). These functions are defined in
<arpa/inet.h>. This lead to some problems because they are defined in
<rtems/endian.h> too. Add NTOHL, ... to
<rtems/rtems_bsdnet_internal.h>.
Update #2408.
The size of the sample executables without this option were:
87040 1728 7824 96592 17950 base_sp.exe
96176 1696 7424 105296 19b50 hello.exe
30672 1280 3888 35840 8c00 minimum.exe
559904 5632 19312 584848 8ec90 fileio.exe
106144 1808 7936 115888 1c4b0 nsecs.exe
180688 2096 8416 191200 2eae0 paranoia.exe
90784 1728 7856 100368 18810 ticker.exe
89248 1760 11264 102272 18f80 unlimited.exe
835456 21520 14896 871872 d4dc0 cxx_iostream.exe
186336 2144 7968 196448 2ff60 cdtest.exe
180544 2224 9648 192416 2efa0 capture.exe
The size of the sample executables with this option enabled were:
78496 1648 7760 87904 15760 base_sp.exe
86560 1600 7344 95504 17510 hello.exe
23360 1184 3840 28384 6ee0 minimum.exe
542624 5568 18976 567168 8a780 fileio.exe
98752 1744 7872 108368 1a750 nsecs.exe
171792 2032 8368 182192 2c7b0 paranoia.exe
83040 1648 7792 92480 16940 ticker.exe
79984 1664 11184 92832 16aa0 unlimited.exe
162128 2112 7616 171856 29f50 cxx_iostream.exe
169856 2048 7888 179792 2be50 cdtest.exe
169904 2128 9584 181616 2c570 capture.exe
Notepads where a feature of RTEMS' tasks that simply functioned in
the same way as POSIX keys or threaded local storage (TLS). They were
introduced well before per task variables, which are also deprecated,
and were barely used in favor of their POSIX alternatives.
In addition to their scarce usage, Notepads took up unnecessary memory.
For each task:
- 16 32-bit integers were allocated.
- A total of 64 bytes per task per thread.
This is especially critical in low memory and safety-critical applications.
They are also defined as uint32_t, and therefore are not guaranteed to
hold a pointer.
Lastly, they are not portable solutions for SMP and uniprocessor systems,
like POSIX keys and TLS.
updates #2493.
