* Makefile.am, preinstall.am: Use shared stub coverhd.h
* include/coverhd.h: Removed.
* Makefile.am: Eliminate bsp.am. Build startup files as side-effect
of building libbspstart.a, using automake-rules.
* clock/clock.c: include "../../../shared/clockdrv_shell.h".
* Makefile.am: Eliminate *_SOURCES.
* Makefile.am: Move noinst_LIBRARIES = libbsp.a before its
components.
* Makefile.am: Cleanup ../../shared/include/bootcard.h handling.
* Makefile.am, configure.ac: Use standardized bsp_cleanup() which can
optionally print a message, poll for user to press key, and call
bsp_reset(). Using this eliminates the various bsp_cleanup()
implementations which had their own implementation and variety of
string constants.
* startup/bspclean.c: Removed.
* Makefile.am, startup/linkcmds, startup/linkcmdsflash,
startup/linkcmdsram: Use top level shared bsp_get_work_area()
implementation.
* Makefile.am, configure.ac, startup/bspstart.c, startup/linkcmds,
startup/linkcmdsflash, startup/linkcmdsram: Add use of
bsp_get_work_area() in its own file and rely on BSP Framework to
perform more initialization. Remove unnecessary includes of
rtems/libio.h and rtems/libcsupport.h.
* Makefile.am: Rework to avoid .rel files.
* Makefile.am, startup/bspstart.c: Moved most of the remaining CPU
Table fields to the Configuration Table. This included
pretasking_hook, predriver_hook, postdriver_hook, idle_task,
do_zero_of_workspace, extra_mpci_receive_server_stack,
stack_allocate_hook, and stack_free_hook. As a side-effect of this
effort some multiprocessing code was made conditional and some style
clean up occurred.
* Makefile.am: Merge c_rtems_main() into boot_card(). This eliminated a
file and simplified initialization.
* Makefile.am: Remove superfluous -DASM.
* Makefile.am: Add preinstall.am.
* .cvsignore, Makefile.am, README, bsp_specs, configure.ac,
clock/clock.c, console/console.c, include/bsp.h,
include/bspopts.h.in, include/coverhd.h, include/tm27.h,
network/network.c, start/start.S, startup/bspclean.c,
startup/bspstart.c, startup/init5282.c, startup/linkcmds,
startup/linkcmdsflash, startup/linkcmdsram, timer/timer.c: New files.
