closes #2546.
closes #2544.
closes #2543.
closes #2444.
closes #2445.
* acinclude.m4: Add mcf5225x BSP.
* acinclude.m4: Add mcf52235 and mcf5329. Regenerate.
* acinclude.m4: Regeneration to add new BSPs.
updated haleakala BSP
added MPC55xx BSP
added genmcf548x BSP
(shared handler and handler with a handle).
* acinclude.m4: Regenerated.
* shared/m68kbspgetworkarea.c: Fix extern type to RamSize.
* shared/m68kpretaskinghook.c: Do not handle the RAM allocation if
the BSP is handling it.
* acinclude.m4: Add the mcf52235 BSP.
* dmv152/.cvsignore, dmv152/ChangeLog, dmv152/Makefile.am,
dmv152/bsp_specs, dmv152/configure.ac, dmv152/preinstall.am,
dmv152/times, dmv152/clock/ckinit.c, dmv152/console/console.c,
dmv152/include/.cvsignore, dmv152/include/bsp.h,
dmv152/include/coverhd.h, dmv152/include/tm27.h,
dmv152/spurious/spinit.c, dmv152/startup/bspclean.c,
dmv152/startup/bspstart.c, dmv152/startup/linkcmds,
dmv152/startup/vmeintr.c, dmv152/timer/timer.c,
dmv152/timer/timerisr.S: Removed.
* acinclude.m4: Add the av5282 BSP.
* acinclude.m4: Added mcf5235.
* .cvsignore, ChangeLog, Makefile.am, README, bsp_specs, configure.ac,
times, console/.cvsignore, console/console-io.c, include/.cvsignore,
include/bsp.h, include/coverhd.h, include/tm27.h, network/network.c,
start/.cvsignore, start/start.S, startup/.cvsignore,
startup/bspclean.c, startup/bspstart.c, startup/init5272.c,
startup/linkcmds: New files.
* acinclude.m4: Regenerate.
* acinclude.m4: Remove efi68k and efi332 references as they are no
longer in the tree.
* acinclude.m4: Reflect changes to bootstrap.
* configure.ac: Remove RTEMS_CHECK_CUSTON_BSP.
* acinclude.m4: Added mcf5206elite.
* acinclude.m4: New file.
