not updated.
The following BSPs do not have tick support so the tests fail:
arm1136jfs
arm1136js
arm7tdmi
arm920
armcortexa9 (does not run any more)
avrtest
h8sim
h8sxsim
m32csim
m32rsim
moxiesim
simsh1
simsh2
simsh4
v850e1sim
v850e2sim
v850e2v3sim
v850esim
v850essim
v850sim
This list was provided by Joel in the following post:
http://www.rtems.org/pipermail/rtems-devel/2014-April/006526.html
The TLS section symbols had wrong values in case of an empty TLS data
section and a nonempty TLS BSS section.
This is necessary to add tests that use the cache manager. For example
to get better estimates of worst-case timings.
Conflicts:
for details.
* Makefile.am: Don't reference non-existing files.
* include/bsp.h:
* startup/bspreset.c: New file.
* Makefile.am, configure.ac, console/console-io.c, include/bsp.h,
start/start.S: Create dedicated bsp_reset() and clean up.
* start/start.S: Pass 0/NULL for argc/argv.
* make/custom/m32rsim.cfg: Remove RTEMS_BSP_FAMILY.
* make/custom/m32rsim.cfg: New (relocated from /make/custom).
* configure.ac: Remove RTEMS_BSP_BOOTCARD_OPTIONS.
* configure.ac: Rename BSP_BOOTCARD_OPTIONS to
RTEMS_BSP_BOOTCARD_OPTIONS. Add RTEMS_BSP_CLEANUP_OPTIONS so all BSPs
have the same options.
* start/start.S: Update for boot_card command line change.
* bsp_specs: Move -e start from *link to *startfile to avoid warning
for undefined entry symbol when linking relocatables with binutils
2.19.
* .cvsignore: New file.
* ChangeLog, Makefile.am, acinclude.m4, configure.ac: New files.
* .cvsignore, ChangeLog, Makefile.am, bsp_specs, configure.ac,
preinstall.am, console/console-io.c, console/syscalls.S,
console/trap0.S, include/.cvsignore, include/bsp.h, include/tm27.h,
start/start.S, startup/linkcmds: New files.
