Conflicts:
for details.
* Makefile.am: Don't reference non-existing files.
* include/bsp.h:
* startup/bspreset.c: New file.
* Makefile.am, configure.ac, console/console-io.c, include/bsp.h,
start/start.S: Create dedicated bsp_reset() and clean up.
* start/start.S: Pass 0/NULL for argc/argv.
* make/custom/m32rsim.cfg: Remove RTEMS_BSP_FAMILY.
* make/custom/m32rsim.cfg: New (relocated from /make/custom).
* configure.ac: Remove RTEMS_BSP_BOOTCARD_OPTIONS.
* configure.ac: Rename BSP_BOOTCARD_OPTIONS to
RTEMS_BSP_BOOTCARD_OPTIONS. Add RTEMS_BSP_CLEANUP_OPTIONS so all BSPs
have the same options.
* start/start.S: Update for boot_card command line change.
* bsp_specs: Move -e start from *link to *startfile to avoid warning
for undefined entry symbol when linking relocatables with binutils
2.19.
* .cvsignore: New file.
* ChangeLog, Makefile.am, acinclude.m4, configure.ac: New files.
* .cvsignore, ChangeLog, Makefile.am, bsp_specs, configure.ac,
preinstall.am, console/console-io.c, console/syscalls.S,
console/trap0.S, include/.cvsignore, include/bsp.h, include/tm27.h,
start/start.S, startup/linkcmds: New files.
