Update #3285.
Update #3285.
* bsps/shared/cache
Update #3285.
line option.
may suppress warnings.
erc32, imx, qoriq, etc.
* cpukit/include
* cpukit/libnetworking
* bsps/include
* bsps/@RTEMS_CPU@/include
order.
Update #3254.
This is necessary to pick up mandatory flags provided by the build
system.
Update #3254.
EXTRA_DIST += foobar
in fragments.
Update #3254.
Updates #3520.
Updates #3520.
Updates #3520.
Patch was not intended to be pushed yet.
Updates #3520.
Done:
arm
bfin
epiphany
i386
lm32
m32c
mips
moxie
nios2
or1k
powerpc
riscv
sh
sparc
sparc64
v850
To do:
m68k
Differences noted:
+ endfile was sometimes before startfile
+ endfile sometimes was hard-coded and did not have -qrtems version
+ Should -e XXX (e.g. entry point) be in linkcmds?
+ Should -u XXX (e.g. undefined symbols) be in linkcmds?
+ Typos: Odd spacing, "old_endfiles" typo, and *(old_endfiles) (not %)
+ nios2: Referenced crtnn.o not crtn.o (error)
Need to revisit:
+ m32c, moxie, sparc64 includes !nostdlib which is not used elsewhere
+ sh has -EL/-EB mapping. Why needed?
+ sparc64 didn't include crti.o/crtn.o but it is part of toolset
+ v850 uses something like this for link and end_file:
"%{qrtems: %(old_link)}"
This means that these are unnecessary. Try this on all.
+ mips uses old_link all the time also.
+ arm/tms750 adds -EB.
+ powerpc: Why do we have rtems_crt* and not use something from GCC?
Updates #3520.
Updates #3250.
header file.
Update #3254.
maintain.
Update #3254.
BSP_PRESS_KEY_FOR_RESET=0
BSP_RESET_BOARD_AT_EXIT=1
BSP_PRINT_EXCEPTION_CONTEXT=1
Update #3239.
Closes #3025.
Change the testsuite configuration files to hold state information about
a test. The states are:
exclude - Do not build the test
expected-fail - The test is expected to fail
indeterminate - The test may pass or may fail
A message is printed just after the test's BEGIN message to indicate
there is a special state for the test. No state message means the test
is expected to pass.
This support requires tests are correctly written to the use standard
support to begin and end a test.
updates #2577.
For the m32csim BSP variant without this option sample executables
sizes were as follows:
143148 1118 4664 148930 245c2 ticker.exe
55140 584 876 56600 dd18 minimum.exe
268638 1804 6598 277040 43a30 capture.exe
161226 1184 4712 167122 28cd2 nsecs.exe
389500 1518 5176 396194 60ba2 paranoia.exe
135256 1118 4638 141012 226d4 base_sp.exe
139728 1146 6482 147356 23f9c unlimited.exe
165500 1092 4638 171230 29cde hello.exe
For the m32csim BSP variant with this option sample executables
137586 1096 4526 143208 22f68 ticker.exe
31136 454 738 32328 7e48 minimum.exe
252540 1764 6458 260762 3fa9a capture.exe
155716 1162 4570 161448 276a8 nsecs.exe
378606 1492 5038 385136 5e070 paranoia.exe
124526 1092 4500 130118 1fc46 base_sp.exe
128746 1120 6344 136210 21412 unlimited.exe
154278 1066 4500 159844 27064 hello.exe
Update #2408.
This avoids potential dead code in _Thread_Handler(). It gets rid of
the dangerous function pointer casts.
Update #2514.
Update #2408.
Fix broken RTEMS linker set descriptions introduced by
b618d8cfc54f84d4ed03dc7b7fa510c872e6128a.
Update #2408.
do
echo $b
# echo $g
-i $b
done
Close #2219.
The file console-polled.h provides the prototypes for the three
required methods when implementing a single port polled console
driver. This paradigm is common on simulators and simple hardware.
+ Updated the BSPs Makefile.am to make console-polled.h available.
+ Regenerated the BSPs preinstall.sm.
+ Updated console support files to include <bsp/console-polled.h>.
+ Updated console support files to make printk() support method static.
output.
The first pass at building these was without networking enabled.
This pass addresses that plus accounts for some new BSPs which
needed testsuite.tcfg files and BSPs which could not link tests
which had been added since the first pass.
The following BSPs do not have tick support so the tests fail:
arm1136jfs
arm1136js
arm7tdmi
arm920
armcortexa9 (does not run any more)
avrtest
h8sim
h8sxsim
m32csim
m32rsim
moxiesim
simsh1
simsh2
simsh4
v850e1sim
v850e2sim
v850e2v3sim
v850esim
v850essim
v850sim
This list was provided by Joel in the following post:
http://www.rtems.org/pipermail/rtems-devel/2014-April/006526.html
The TLS section symbols had wrong values in case of an empty TLS data
section and a nonempty TLS BSS section.
This is necessary to add tests that use the cache manager. For example
to get better estimates of worst-case timings.
