BSP_PRESS_KEY_FOR_RESET=0
BSP_RESET_BOARD_AT_EXIT=1
BSP_PRINT_EXCEPTION_CONTEXT=1
Update #3239.
Remove old ISR parameter since is not used by the clock driver shell.
Make an implementation optional.
Update #3139.
Update #2133.
Make Clock_driver_support_shutdown_hardware() optional. This avoids
the atexit() support on memory constrained targets.
Change bsp_interrupt_vector_enable() and bsp_interrupt_vector_disable()
to not return a status code. Add bsp_interrupt_assert() and use it to
validate the vector number in the vector enable/disable implementations.
Adding modified FreeBSD headers to synchronize RTEMS termios with
FreeBSD. Modify termios to support dedicated input and output baud for
termios structure. Updated BSPs to use dedicated input and output baud
in termios structure. Updated tools to use dedicated input and output
baud in termios structure. Updated termios testsuites to use dedicated
input and output baud in termios structure.
Close #2897.
Update #2825.
warnings
updates #2577.
For the milkymist BSP variant without this option sample executables
sizes were as follows:
101160 9044 13333 123537 1e291 ticker.exe
30888 2676 9169 42733 a6ed minimum.exe
592200 90020 26557 708777 ad0a9 fileio.exe
456048 64528 42565 563141 897c5 pppd.exe
203752 25404 16241 245397 3be95 capture.exe
118216 10704 13437 142357 22c15 nsecs.exe
197848 22468 13981 234297 39339 paranoia.exe
97496 8760 13301 119557 1d305 base_sp.exe
100392 9120 17141 126653 1eebd unlimited.exe
121032 7720 13309 142061 22aed hello.exe
289340 28120 20653 338113 528c1 loopback.exe
For the milkymist BSP variant with this option sample executables
93464 8748 13333 115545 1c359 ticker.exe
17144 1308 9133 27585 6bc1 minimum.exe
574024 87296 26301 687621 a7e05 fileio.exe
415668 60652 41837 518157 7e80d pppd.exe
190920 24712 16233 231865 389b9 capture.exe
111800 10404 13405 135609 211b9 nsecs.exe
187272 22064 13949 223285 36835 paranoia.exe
87656 8440 13301 109397 1ab55 base_sp.exe
89048 8736 17149 114933 1c0f5 unlimited.exe
108888 7316 13309 129513 1f9e9 hello.exe
262820 26764 20557 310141 4bb7d loopback.exe
updates #2577.
For the lm32_evr BSP variant without this option sample executables
195764 6892 13077 215733 34ab5 ticker.exe
84212 2264 9169 95645 1759d minimum.exe
1077108 82852 26293 1186253 1219cd fileio.exe
763500 56340 44493 864333 d304d pppd.exe
344948 22148 15977 383073 5d861 capture.exe
211876 8472 13169 233517 3902d nsecs.exe
330020 18636 13685 362341 58765 paranoia.exe
185956 6452 13053 205461 32295 base_sp.exe
194516 6656 16893 218065 353d1 unlimited.exe
202164 5400 13013 220577 35da1 hello.exe
474728 23220 20389 518337 7e8c1 loopback.exe
For the lm32_evr BSP variant with this option sample executables
186388 6792 13045 206225 32591 ticker.exe
53140 1124 9137 63401 f7a9 minimum.exe
1049556 80336 26045 1155937 11a361 fileio.exe
685632 55056 43757 784445 bf83d pppd.exe
323588 21400 15953 360941 581ed capture.exe
203540 8352 13137 225029 36f05 nsecs.exe
316612 18512 13653 348777 55269 paranoia.exe
172724 6352 13021 192097 2ee61 base_sp.exe
176708 6528 16837 200073 30d89 unlimited.exe
182900 5260 13021 201181 311dd hello.exe
436064 22840 20293 479197 74fdd loopback.exe
Update #2408.
Update #2408.
Update #2408.
do
echo $b
# echo $g
-i $b
done
Update #2271.
Lay groundwork for a simulator configuration configuration
for the Milkymist. This is needed to use the shared code.
output.
not updated.
The TLS section symbols had wrong values in case of an empty TLS data
section and a nonempty TLS BSS section.
This is necessary to add tests that use the cache manager. For example
to get better estimates of worst-case timings.
Add doxygen to the header files in the /lm32/milymist/include directory.
Add doxygen to the header files in the /lm32/lm32_evr/include directory.
