* shared/start/start.S: Finish merging change.
* shared/start/start.S: Add support for qemu-system-lm32 shutdown
device.
* shared/gdbstub/lm32-stub.c: Fix wrong computation of negative branch
targets (thanks to Manfred Scheible <mscheible@husware.de>.
* shared/tsmac/tsmac.c: Remove unused vars.
Let rtems_tsmac_driver_attach return 1.
* shared/console/console.c: Use int as return type of
BSP_uart_polled_read.
* shared/start/start.S: Export crt0 symbol because the debug.S uses
that.
* shared/start/start.S: Confirmed OK by mwalle.
* shared/gdbstub/README, shared/gdbstub/gdb_if.h,
shared/gdbstub/lm32-debug.S, shared/gdbstub/lm32-stub.c: New files.
* shared/start/start.S: Update for boot_card command line change.
* shared/start/start.S: Now calls boot_card.
* shared/clock/ckinit.c, shared/start/start.S, shared/timer/timer.c:
Run better on simulator. Timer is probably not right yet but
* shared/clock/ckinit.c: Use shared Clock Driver Template and support
fast idle on simulator.
* ChangeLog, Makefile.am, README, acinclude.m4, configure.ac,
shared/clock/ckinit.c, shared/clock/clock.h,
shared/console/console.c, shared/console/uart.c,
shared/console/uart.h, shared/start/start.S,
shared/startup/bspstart.c, shared/startup/setvec.c,
shared/timer/timer.c, shared/tsmac/dp83848phy.h,
shared/tsmac/tsmac.c, shared/tsmac/tsmac.h: New files.
