line option.
may suppress warnings.
erc32, imx, qoriq, etc.
* cpukit/include
* cpukit/libnetworking
* bsps/include
* bsps/@RTEMS_CPU@/include
order.
Update #3254.
Update #3254.
Remove old ISR parameter since is not used by the clock driver shell.
Make an implementation optional.
Update #3139.
Update #2133.
Make Clock_driver_support_shutdown_hardware() optional. This avoids
the atexit() support on memory constrained targets.
Change bsp_interrupt_vector_enable() and bsp_interrupt_vector_disable()
to not return a status code. Add bsp_interrupt_assert() and use it to
validate the vector number in the vector enable/disable implementations.
Adding modified FreeBSD headers to synchronize RTEMS termios with
FreeBSD. Modify termios to support dedicated input and output baud for
termios structure. Updated BSPs to use dedicated input and output baud
in termios structure. Updated tools to use dedicated input and output
baud in termios structure. Updated termios testsuites to use dedicated
input and output baud in termios structure.
Close #2897.
Update #2271.
output.
TOD_MILLISECONDS_TO_TICKS().
Termios notifies now the driver about an inactive transmit with the
length argument set to zero.
Add and use rtems_blkdev_request_done(). Block device transfer requests
must signal the completion status now with rtems_blkdev_request_done().
The return value of the block device IO control will be ignored for
transfer requests.
The first parameter of rtems_blkdev_request_cb is now the transfer
request structure.
Renamed rtems_blkdev_request::req_done to rtems_blkdev_request::done to
break third party drivers at compile time, otherwise this API change
would result in runtime errors.
Add reserved system events RTEMS_EVENT_SYSTEM_NETWORK_SBWAIT and
RTEMS_EVENT_SYSTEM_NETWORK_SOSLEEP.
Add and use rtems_bsdnet_event_send().
Leave the task of providing a suitable firmware for the Milkymist softusb
core to the application instead of having an inflexible array in the driver.
Signed-off-by: Gedare Bloom <gedare@rtems.org>
Slightly adjust video timing registers since we had problems with a few screens and the previous values.
Forward MIDI messages from the softusb controller to the application.
* ChangeLog: Add PR number to ChangeLog entry
* milkymist_midi/midi.c: move MIDI message detection from higher layers
to the MIDI interrupt handler
PR 1972/bsps
* milkymist_video/milkymist_video.h, milkymist_video/video.c: Adds an
ioctl to implement selection of composite on any connector, S-Video
and Component sources on the Milkymist One.
PR 1970/bsps
* milkymist_clock/ckinit.c, milkymist_console/console.c,
milkymist_console/uart.c, milkymist_timer/timer.c: Support for the
new Milkymist sysctl and clock frequency detection.
PR 1966/bsps
* milkymist_console/console.c, milkymist_console/uart.c,
milkymist_console/uart.h, milkymist_midi/midi.c: support for the new
UART core and interrupt map
PR 1869/bsps
* milkymist_networking/mm_crc32.c: Removed.
PR 1869/bsps
* startup/bspclean.c: New file.
* include/tm27.h: Removed.
* ChangeLog, Makefile.am, README, preinstall.am, include/bsp.h,
include/system_conf.h, make/custom/milkymist.cfg, startup/linkcmds:
Complete BSP for Milkymist One supporting Milkymist SOC 1.0.x.
Includes new or updated drivers for:
- Multi-standard video input (PAL/SECAM/NTSC)
- Two DMX512 (RS485) ports
- MIDI IN and MIDI OUT ports
- VGA output
- AC'97 audio
- NOR flash
- 10/100 Ethernet
- Memory card (experimental and incomplete)
- USB host connectors (input devices only)
- RC5 infrared receiver
- RS232 debug port
