* | lm32/shared/milkymist_video/video.c: Include <rtems/bspIo.h> | Joel Sherrill | 2017-04-05 | 1 | -0/+1 |
* | Change all references of rtems.com to rtems.org. | Chris Johns | 2014-03-21 | 2 | -2/+2 |
* | lm32: Add doxygen | Chirayu Desai | 2013-12-23 | 1 | -0/+15 |
* | Remove All CVS Id Strings Possible Using a Script | Joel Sherrill | 2012-05-11 | 2 | -4/+0 |
* | 2011-11-27 Sebastien Bourdeauducq <seb@tmplab.org> | Gedare Bloom | 2011-11-27 | 2 | -2/+48 |
| | | | | | | | PR 1972/bsps * milkymist_video/milkymist_video.h, milkymist_video/video.c: Adds an ioctl to implement selection of composite on any connector, S-Video and Component sources on the Milkymist One. | ||||
* | 2011-08-01 Sebastien Bourdeauducq <sebastien.bourdeauducq@gmail.com> | Joel Sherrill | 2011-08-01 | 2 | -0/+423 |
PR 1869/bsps * startup/bspclean.c: New file. * include/tm27.h: Removed. * ChangeLog, Makefile.am, README, preinstall.am, include/bsp.h, include/system_conf.h, make/custom/milkymist.cfg, startup/linkcmds: Complete BSP for Milkymist One supporting Milkymist SOC 1.0.x. Includes new or updated drivers for: - Multi-standard video input (PAL/SECAM/NTSC) - Two DMX512 (RS485) ports - MIDI IN and MIDI OUT ports - VGA output - AC'97 audio - NOR flash - 10/100 Ethernet - Memory card (experimental and incomplete) - USB host connectors (input devices only) - RC5 infrared receiver - RS232 debug port |
