2018-04-23 | bsps/lm32: Move shared drivers to bsps | Sebastian Huber | 1 | -143/+0 | |
This patch is a part of the BSP source reorganization. Update #3285. | |||||
2018-01-04 | bsps/lm32: Use public include path | Chris Johns | 1 | -1/+1 | |
Update #3254. | |||||
2017-04-05 | lm32/shared/milkymist_pfpu/pfpu.c: Fix indentation and braces | Joel Sherrill | 1 | -4/+5 | |
2014-03-21 | Change all references of rtems.com to rtems.org. | Chris Johns | 1 | -1/+1 | |
2012-05-11 | Remove All CVS Id Strings Possible Using a Script | Joel Sherrill | 1 | -2/+0 | |
Script does what is expected and tries to do it as smartly as possible. + remove occurrences of two blank comment lines next to each other after Id string line removed. + remove entire comment blocks which only exited to contain CVS Ids + If the processing left a blank line at the top of a file, it was removed. | |||||
2011-08-01 | 2011-08-01 Sebastien Bourdeauducq <sebastien.bourdeauducq@gmail.com> | Joel Sherrill | 1 | -0/+144 | |
PR 1869/bsps * startup/bspclean.c: New file. * include/tm27.h: Removed. * ChangeLog, Makefile.am, README, preinstall.am, include/bsp.h, include/system_conf.h, make/custom/milkymist.cfg, startup/linkcmds: Complete BSP for Milkymist One supporting Milkymist SOC 1.0.x. Includes new or updated drivers for: - Multi-standard video input (PAL/SECAM/NTSC) - Two DMX512 (RS485) ports - MIDI IN and MIDI OUT ports - VGA output - AC'97 audio - NOR flash - 10/100 Ethernet - Memory card (experimental and incomplete) - USB host connectors (input devices only) - RC5 infrared receiver - RS232 debug port |
