Add reserved system events RTEMS_EVENT_SYSTEM_NETWORK_SBWAIT and
RTEMS_EVENT_SYSTEM_NETWORK_SOSLEEP.
Add and use rtems_bsdnet_event_send().
PR 1869/bsps
* milkymist_networking/mm_crc32.c: Removed.
PR 1869/bsps
* startup/bspclean.c: New file.
* include/tm27.h: Removed.
* ChangeLog, Makefile.am, README, preinstall.am, include/bsp.h,
include/system_conf.h, make/custom/milkymist.cfg, startup/linkcmds:
Complete BSP for Milkymist One supporting Milkymist SOC 1.0.x.
Includes new or updated drivers for:
- Multi-standard video input (PAL/SECAM/NTSC)
- Two DMX512 (RS485) ports
- MIDI IN and MIDI OUT ports
- VGA output
- AC'97 audio
- NOR flash
- 10/100 Ethernet
- Memory card (experimental and incomplete)
- USB host connectors (input devices only)
- RC5 infrared receiver
- RS232 debug port
* shared/milkymist_networking/network.c:
* shared/milkymist_ac97/ac97.c, shared/milkymist_clock/ckinit.c,
shared/milkymist_clock/clock.h, shared/milkymist_console/console.c,
shared/milkymist_console/uart.c, shared/milkymist_console/uart.h,
shared/milkymist_framebuffer/framebuffer.c,
shared/milkymist_gpio/gpio.c, shared/milkymist_networking/mm_crc32.c,
shared/milkymist_networking/network.c,
shared/milkymist_networking/network.h,
shared/milkymist_timer/timer.c: New files.
