Adding modified FreeBSD headers to synchronize RTEMS termios with
FreeBSD. Modify termios to support dedicated input and output baud for
termios structure. Updated BSPs to use dedicated input and output baud
in termios structure. Updated tools to use dedicated input and output
baud in termios structure. Updated termios testsuites to use dedicated
input and output baud in termios structure.
Close #2897.
Termios notifies now the driver about an inactive transmit with the
length argument set to zero.
PR 1970/bsps
* milkymist_clock/ckinit.c, milkymist_console/console.c,
milkymist_console/uart.c, milkymist_timer/timer.c: Support for the
new Milkymist sysctl and clock frequency detection.
PR 1966/bsps
* milkymist_console/console.c, milkymist_console/uart.c,
milkymist_console/uart.h, milkymist_midi/midi.c: support for the new
UART core and interrupt map
PR 1869/bsps
* startup/bspclean.c: New file.
* include/tm27.h: Removed.
* ChangeLog, Makefile.am, README, preinstall.am, include/bsp.h,
include/system_conf.h, make/custom/milkymist.cfg, startup/linkcmds:
Complete BSP for Milkymist One supporting Milkymist SOC 1.0.x.
Includes new or updated drivers for:
- Multi-standard video input (PAL/SECAM/NTSC)
- Two DMX512 (RS485) ports
- MIDI IN and MIDI OUT ports
- VGA output
- AC'97 audio
- NOR flash
- 10/100 Ethernet
- Memory card (experimental and incomplete)
- USB host connectors (input devices only)
- RC5 infrared receiver
- RS232 debug port
* shared/milkymist_ac97/ac97.c, shared/milkymist_clock/ckinit.c,
shared/milkymist_clock/clock.h, shared/milkymist_console/console.c,
shared/milkymist_console/uart.c, shared/milkymist_console/uart.h,
shared/milkymist_framebuffer/framebuffer.c,
shared/milkymist_gpio/gpio.c, shared/milkymist_networking/mm_crc32.c,
shared/milkymist_networking/network.c,
shared/milkymist_networking/network.h,
shared/milkymist_timer/timer.c: New files.
