path: root/c/src/lib/libbsp/lm32/shared/milkymist_buttons/milkymist_buttons.h (unfollow)
2018-01-25Remove make preinstallChris Johns1-59/+0
2014-03-21Change all references of rtems.com to rtems.org.Chris Johns1-1/+1
2013-12-23lm32: Add doxygenChirayu Desai1-0/+15
2012-05-11Remove All CVS Id Strings Possible Using a ScriptJoel Sherrill1-2/+0
Script does what is expected and tries to do it as smartly as possible. + remove occurrences of two blank comment lines next to each other after Id string line removed. + remove entire comment blocks which only exited to contain CVS Ids + If the processing left a blank line at the top of a file, it was removed.
2011-08-012011-08-01 Sebastien Bourdeauducq <sebastien.bourdeauducq@gmail.com>Joel Sherrill1-0/+46
PR 1869/bsps * startup/bspclean.c: New file. * include/tm27.h: Removed. * ChangeLog, Makefile.am, README, preinstall.am, include/bsp.h, include/system_conf.h, make/custom/milkymist.cfg, startup/linkcmds: Complete BSP for Milkymist One supporting Milkymist SOC 1.0.x. Includes new or updated drivers for: - Multi-standard video input (PAL/SECAM/NTSC) - Two DMX512 (RS485) ports - MIDI IN and MIDI OUT ports - VGA output - AC'97 audio - NOR flash - 10/100 Ethernet - Memory card (experimental and incomplete) - USB host connectors (input devices only) - RC5 infrared receiver - RS232 debug port
