2018-04-20 | bsps: Move console drivers to bsps | Sebastian Huber | 1 | -73/+0 | |
This patch is a part of the BSP source reorganization. Update #3285. | |||||
2014-10-20 | lm32 BSP shared and lm32_evr: Fix BSPs | Joel Sherrill | 1 | -3/+6 | |
2014-03-21 | Change all references of rtems.com to rtems.org. | Chris Johns | 1 | -1/+1 | |
2012-05-11 | Remove All CVS Id Strings Possible Using a Script | Joel Sherrill | 1 | -2/+0 | |
Script does what is expected and tries to do it as smartly as possible. + remove occurrences of two blank comment lines next to each other after Id string line removed. + remove entire comment blocks which only exited to contain CVS Ids + If the processing left a blank line at the top of a file, it was removed. | |||||
2009-11-29 | Whitespace removal. | Ralf Corsepius | 1 | -1/+1 | |
2008-12-04 | 2008-12-04 Jukka Pietarinen <jukka.pietarinen@mrf.fi> | Joel Sherrill | 1 | -0/+72 | |
* ChangeLog, Makefile.am, README, acinclude.m4, configure.ac, shared/clock/ckinit.c, shared/clock/clock.h, shared/console/console.c, shared/console/uart.c, shared/console/uart.h, shared/start/start.S, shared/startup/bspstart.c, shared/startup/setvec.c, shared/timer/timer.c, shared/tsmac/dp83848phy.h, shared/tsmac/tsmac.c, shared/tsmac/tsmac.h: New files. |
