Update #3285.
Remove old ISR parameter since is not used by the clock driver shell.
Make an implementation optional.
Update #3139.
Make Clock_driver_support_shutdown_hardware() optional. This avoids
the atexit() support on memory constrained targets.
Update #2271.
* shared/clock/ckinit.c, shared/start/start.S, shared/timer/timer.c:
Run better on simulator. Timer is probably not right yet but
* shared/clock/ckinit.c: Use shared Clock Driver Template and support
fast idle on simulator.
* ChangeLog, Makefile.am, README, acinclude.m4, configure.ac,
shared/clock/ckinit.c, shared/clock/clock.h,
shared/console/console.c, shared/console/uart.c,
shared/console/uart.h, shared/start/start.S,
shared/startup/bspstart.c, shared/startup/setvec.c,
shared/timer/timer.c, shared/tsmac/dp83848phy.h,
shared/tsmac/tsmac.c, shared/tsmac/tsmac.h: New files.
* clock/ckinit.c: Remove unnecessary includes of rtems/libcsupport.h
and rtems/libio.h.
* clock/ckinit.c: The Shared Memory Driver no longer requires the
special IOCTL in Clock_control. This was a hack which has existed
since before the Classic API Timer Manager was implemented. All
implementations of and references to Clock_control were removed.
* clock/ckinit.c, include/bsp.h, startup/bspstart.c: Eliminate copies
of the Configuration Table. Use the RTEMS provided accessor macros to
obtain configuration fields.
* clock/ckinit.c, shmsupp/getcfg.c, shmsupp/lock.c,
startup/bspstart.c, timer/timer.c, timer/timerisr.c: Convert to
using c99 fixed size types.
* clock/ckinit.c, console/console.c, include/bsp.h, shmsupp/addrconv.c,
shmsupp/getcfg.c, shmsupp/lock.c, shmsupp/mpisr.c,
startup/bspclean.c, startup/bspstart.c, startup/linkcmds,
startup/main.c, startup/setvec.c, timer/timer.c, timer/timerisr.c:
URL for license changed.
like signal dispatching.
correct Information block.
