do
echo $b
# echo $g
-i $b
done
Lay groundwork for a simulator configuration configuration
for the Milkymist. This is needed to use the shared code.
not updated.
The TLS section symbols had wrong values in case of an empty TLS data
section and a nonempty TLS BSS section.
This is necessary to add tests that use the cache manager. For example
to get better estimates of worst-case timings.
Add doxygen to the header files in the /lm32/milymist/include directory.
Do not return from rtems_initialize_start_multitasking() and call
rtems_fatal() instead with a fatal source of RTEMS_FATAL_SOURCE_EXIT and
a fatal code with the exit status.
Remove all bsp_cleanup() functions. The boot_card() is now a no return
function.
Use <bsp/bootcard.h> to get prototype for bsp_cleanup(). Fix
bsp_cleanup() definition if necessary.
Conflicts:
We increased PMEM to 8 kB but never updated SOFTUSB_PMEM_SIZE.
This didn't have much of an effect because all we used it for was
to zero unused program memory - which we should never touch
anyway.
But now that "usb load" in FN uses SOFTUSB_PMEM_SIZE, this caused
it to silently truncate the firmware, producing rather puzzling
effects.
Signed-off-by: Joel Sherrill <joel.sherrill@oarcorp.com>
PR 1970/bsps
* include/system_conf.h: Support for the new Milkymist sysctl and clock
frequency detection.
PR 1966/bsps
* include/system_conf.h: support for the new UART core and interrupt
map
PR 1869/bsps
* startup/bspclean.c: New file.
* include/tm27.h: Removed.
* ChangeLog, Makefile.am, README, preinstall.am, include/bsp.h,
include/system_conf.h, make/custom/milkymist.cfg, startup/linkcmds:
Complete BSP for Milkymist One supporting Milkymist SOC 1.0.x.
Includes new or updated drivers for:
- Multi-standard video input (PAL/SECAM/NTSC)
- Two DMX512 (RS485) ports
- MIDI IN and MIDI OUT ports
- VGA output
- AC'97 audio
- NOR flash
- 10/100 Ethernet
- Memory card (experimental and incomplete)
- USB host connectors (input devices only)
- RC5 infrared receiver
- RS232 debug port
* .cvsignore: New file.
Add Milkymist BSP developed as part of GSOC 2010.
* ChangeLog, Makefile.am, README, bsp_specs, configure.ac,
preinstall.am, Documentation/uart.txt, include/.cvsignore,
include/bsp.h, include/system_conf.h, include/tm27.h,
make/custom/milkymist.cfg, startup/linkcmds: New files.
