PR 1869/bsps
* startup/bspclean.c: New file.
* include/tm27.h: Removed.
* ChangeLog, Makefile.am, README, preinstall.am, include/bsp.h,
include/system_conf.h, make/custom/milkymist.cfg, startup/linkcmds:
Complete BSP for Milkymist One supporting Milkymist SOC 1.0.x.
Includes new or updated drivers for:
- Multi-standard video input (PAL/SECAM/NTSC)
- Two DMX512 (RS485) ports
- MIDI IN and MIDI OUT ports
- VGA output
- AC'97 audio
- NOR flash
- 10/100 Ethernet
- Memory card (experimental and incomplete)
- USB host connectors (input devices only)
- RC5 infrared receiver
- RS232 debug port
Add Milkymist BSP developed as part of GSOC 2010.
* ChangeLog, Makefile.am, README, bsp_specs, configure.ac,
preinstall.am, Documentation/uart.txt, include/.cvsignore,
include/bsp.h, include/system_conf.h, include/tm27.h,
make/custom/milkymist.cfg, startup/linkcmds: New files.
