do
echo $b
# echo $g
-i $b
done
Lay groundwork for a simulator configuration configuration
for the Milkymist. This is needed to use the shared code.
not updated.
The TLS section symbols had wrong values in case of an empty TLS data
section and a nonempty TLS BSS section.
This is necessary to add tests that use the cache manager. For example
to get better estimates of worst-case timings.
Add doxygen to the header files in the /lm32/lm32_evr/include directory.
Conflicts:
PR 1869/bsps
* README: Merge content from lm32/README which was specific to
this BSP.
* include/irq-config.h: Removed file.
* include/bsp.h: Move extern "C" { }.
* make/custom/lm32_evr.cfg: Remove RTEMS_BSP_FAMILY.
* make/custom/lm32_evr.cfg: New (relocated from /make/custom).
* configure.ac: Remove RTEMS_BSP_BOOTCARD_OPTIONS.
* configure.ac: Rename BSP_BOOTCARD_OPTIONS to
RTEMS_BSP_BOOTCARD_OPTIONS. Add RTEMS_BSP_CLEANUP_OPTIONS so all BSPs
have the same options.
* configure.ac: Add BSP_BOOTCARD_OPTIONS.
* startup/linkcmds: Stack was overlapping work area.
* configure.ac, include/bsp.h: Run better on simulator. Timer is
probably not right yet but
* README: Add fast idle information.
* Makefile.am, configure.ac: Add SIMULATOR_FAST_IDLE,
BSP_PRESS_KEY_FOR_RESET, and BSP_RESET_BOARD_AT_EXIT. Use the standard
bsp_cleanup code.
* README: New file. Include instructions on gdb simulator.
* include/bsp.h: Conditionally include rtems/rtems_bsdnet.h.
* configure.ac: Add RTEMS_CHECK_NETWORKING.
* Makefile.am: Rework.
* startup/linkcmds: Add new sections.
* bsp_specs: Update to reflect comments.
* .cvsignore: New file.
* ChangeLog, Makefile.am, bsp_specs, configure.ac, preinstall.am,
include/.cvsignore, include/bsp.h, include/coverhd.h,
include/irq-config.h, include/system_conf.h, include/tm27.h,
startup/linkcmds: New files.
