2015-07-16 | Most bsp.h: Switch to LIBBSP_@CPU@_@BSP_FAMILY@_H for guard | Joel Sherrill | 1 | -2/+2 | |
This was done by the following script run from libbsp: find * -name bsp.h | xargs -e grep -l "#ifndef.*_BSP_H" | while read b do echo $b cpu=`echo $b | cut -d'/' -f1 | tr '[:lower:]' '[:upper:]' ` bsp=`echo $b | cut -d'/' -f2 | tr '[:lower:]' '[:upper:]' ` g="LIBBSP_${cpu}_${bsp}_BSP_H" # echo $g sed -e "s/ifndef _BSP_H/ifndef ${g}/" \ -e "s/define _BSP_H/define ${g}/" \ -i $b done | |||||
2015-04-05 | lm32 BSPs: Add lm32_evr variant for running on gdb. | Joel Sherrill | 4 | -10/+29 | |
Lay groundwork for a simulator configuration configuration for the Milkymist. This is needed to use the shared code. | |||||
2014-12-05 | Update bug report URL | Sebastian Huber | 1 | -1/+1 | |
2014-10-20 | lm32 BSP shared and lm32_evr: Fix BSPs | Joel Sherrill | 1 | -0/+7 | |
2014-10-13 | lm32/lm32_evr/include/bsp.h: Fix warnings | Joel Sherrill | 1 | -2/+0 | |
2014-08-29 | Regenerate all preinstall.am files. | Chris Johns | 1 | -6/+6 | |
With this patch the preinstall.am files are in a set order and not dependent on now perl implements a hash. | |||||
2014-08-28 | Regenerate all preinstall.am files. | Joel Sherrill | 1 | -3/+3 | |
Apparently, at some point automake output changed and these were not updated. | |||||
2014-04-22 | bsps: Fix TLS support in linker command files | Sebastian Huber | 1 | -1/+3 | |
The TLS section symbols had wrong values in case of an empty TLS data section and a nonempty TLS BSS section. | |||||
2014-03-21 | lm32_evr/include/bsp.h: Remove rtems_bsp_delay() | Joel Sherrill | 1 | -15/+1 | |
2014-03-21 | Change all references of rtems.com to rtems.org. | Chris Johns | 3 | -3/+3 | |
2014-02-24 | bsps: Add empty cache manager | Sebastian Huber | 1 | -0/+5 | |
This is necessary to add tests that use the cache manager. For example to get better estimates of worst-case timings. | |||||
2014-02-04 | bsps: Thread-local storage (TLS) for linkcmds | Sebastian Huber | 1 | -0/+14 | |
2013-12-24 | lm32_evr: improve doxygen | Toma | 4 | -0/+40 | |
Add doxygen to the header files in the /lm32/lm32_evr/include directory. | |||||
2013-08-09 | Use $(EXEEXT) [defaults to "exe"] to generate binaries | Nick Withers | 1 | -1/+1 | |
2013-03-08 | RTEMS: Delete ChangeLog files. | Gedare Bloom | 1 | -89/+0 | |
This commit deletes all RTEMS ChangeLog files. These files have been abandoned since converting to git version control. The historical data may be recovered by checking out any commit before this one. Most of the contents of these ChangeLog files can also be found in the git log. Two external ChangeLog files, ChangeLog.slac and ChangeLog.zlib, remain. | |||||
2012-11-15 | score: Add RTEMS_FATAL_SOURCE_EXIT | Sebastian Huber | 1 | -0/+1 | |
Include <bsp/default-initial-extension.h> in all BSPs. Call rtems_fatal() with RTEMS_FATAL_SOURCE_EXIT as source and the exit() status code as fatal code in every bsp_cleanup(). Move previous bsp_cleanup() code into bsp_fatal_extension(). | |||||
2012-08-06 | Revert "Add bspopts.h.in." | Gedare Bloom | 1 | -39/+0 | |
This reverts commit daffa606cc4a45d93c1f0f4fe365fde0fda6acbb. Conflicts: c/src/lib/libbsp/arm/lpc24xx/include/bspopts.h.in c/src/lib/libbsp/powerpc/mpc55xxevb/include/bspopts.h.in c/src/lib/libbsp/powerpc/qoriq/include/bspopts.h.in Manually deleted conflicting files. | |||||
2012-07-19 | Require automake-1.12.2. | Ralf Corsépius | 1 | -1/+1 | |
2012-07-19 | Require autoconf-2.69. | Ralf Corsépius | 1 | -1/+1 | |
2012-05-24 | Add bspopts.h.in. | Ralf Corsépius | 1 | -0/+39 | |
2012-05-11 | Remove All CVS Id Strings Possible Using a Script | Joel Sherrill | 4 | -9/+0 | |
Script does what is expected and tries to do it as smartly as possible. + remove occurrences of two blank comment lines next to each other after Id string line removed. + remove entire comment blocks which only exited to contain CVS Ids + If the processing left a blank line at the top of a file, it was removed. | |||||
2012-05-04 | Remove CVS-Ids. | Ralf Corsépius | 2 | -6/+0 | |
2012-04-16 | lm32: use shared setvec.c | Gedare Bloom | 1 | -1/+1 | |
2012-02-01 | Remove all .cvsignore files. | Joel Sherrill | 2 | -12/+0 | |
2011-08-02 | 2011-08-02 Sebastien Bourdeauducq <sebastien.bourdeauducq@gmail.com> | Joel Sherrill | 2 | -0/+41 | |
PR 1869/bsps * README: Merge content from lm32/README which was specific to this BSP. | |||||
2011-02-02 | 2011-02-02 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2 | -2/+6 | |
* configure.ac: Require autoconf-2.68, automake-1.11.1. | |||||
2010-04-30 | 2010-04-30 Sebastian Huber <sebastian.huber@embedded-brains.de> | Sebastian Huber | 2 | -44/+4 | |
* include/irq-config.h: Removed file. | |||||
2009-11-29 | Whitespace removal. | Ralf Corsepius | 2 | -6/+6 | |
2009-11-28 | Whitespace removal. | Ralf Corsepius | 1 | -1/+1 | |
2009-11-24 | 2009-11-24 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2 | -4/+8 | |
* include/bsp.h: Move extern "C" { }. | |||||
2009-10-21 | 2009-10-21 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2 | -3/+4 | |
* make/custom/lm32_evr.cfg: Remove RTEMS_BSP_FAMILY. | |||||
2009-10-20 | 2009-10-20 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2 | -1/+5 | |
* configure.ac: Don't add -ansi -fasm to CFLAGS. | |||||
2009-10-15 | 2009-10-15 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2 | -0/+34 | |
* make/custom/lm32_evr.cfg: New (relocated from /make/custom). | |||||
2009-09-15 | 2009-09-15 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2 | -2/+5 | |
* configure.ac: Remove RTEMS_BSP_BOOTCARD_OPTIONS. | |||||
2009-07-16 | 2009-07-16 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2 | -10/+8 | |
* configure.ac: Rename BSP_BOOTCARD_OPTIONS to RTEMS_BSP_BOOTCARD_OPTIONS. Add RTEMS_BSP_CLEANUP_OPTIONS so all BSPs have the same options. | |||||
2009-07-16 | 2009-07-16 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2 | -0/+6 | |
* configure.ac: Add BSP_BOOTCARD_OPTIONS. | |||||
2009-03-30 | 2009-03-30 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2 | -2/+7 | |
* startup/linkcmds: Stack was overlapping work area. | |||||
2009-02-26 | 2009-02-26 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 3 | -10/+16 | |
* configure.ac, include/bsp.h: Run better on simulator. Timer is probably not right yet but | |||||
2009-02-25 | 2009-02-25 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2 | -0/+7 | |
* README: Add fast idle information. | |||||
2009-02-25 | 2009-02-25 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 4 | -3/+39 | |
* Makefile.am, configure.ac: Add SIMULATOR_FAST_IDLE, BSP_PRESS_KEY_FOR_RESET, and BSP_RESET_BOARD_AT_EXIT. Use the standard bsp_cleanup code. * README: New file. Include instructions on gdb simulator. | |||||
2009-02-23 | 2009-02-23 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -0/+1 | |
* include/bsp.h: Conditionally include rtems/rtems_bsdnet.h. | |||||
2009-02-23 | Conditionally include rtems/rtems_bsdnet.h. | Ralf Corsepius | 1 | -0/+6 | |
2009-02-23 | 2009-02-23 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -0/+5 | |
* configure.ac: Add RTEMS_CHECK_NETWORKING. * Makefile.am: Rework. | |||||
2009-02-23 | Rework. | Ralf Corsepius | 1 | -14/+25 | |
2009-02-23 | Add RTEMS_CHECK_NETWORKING. | Ralf Corsepius | 1 | -0/+4 | |
2009-02-21 | 2009-02-21 Michael Walle <michael@walle.cc> | Joel Sherrill | 2 | -1/+8 | |
* startup/linkcmds: Add new sections. | |||||
2008-12-09 | 2008-12-09 Jukka Pietarinen <jukka.pietarinen@mrf.fi> | Joel Sherrill | 2 | -7/+6 | |
* bsp_specs: Update to reflect comments. | |||||
2008-12-05 | 2008-12-05 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2 | -0/+12 | |
* .cvsignore: New file. | |||||
2008-12-04 | 2008-12-04 Jukka Pietarinen <jukka.pietarinen@mrf.fi> | Joel Sherrill | 12 | -0/+889 | |
* ChangeLog, Makefile.am, bsp_specs, configure.ac, preinstall.am, include/.cvsignore, include/bsp.h, include/coverhd.h, include/irq-config.h, include/system_conf.h, include/tm27.h, startup/linkcmds: New files. |
