line option.
may suppress warnings.
erc32, imx, qoriq, etc.
* cpukit/include
* cpukit/libnetworking
* bsps/include
* bsps/@RTEMS_CPU@/include
order.
Update #3254.
* ChangeLog, Makefile.am, README, acinclude.m4, configure.ac,
shared/clock/ckinit.c, shared/clock/clock.h,
shared/console/console.c, shared/console/uart.c,
shared/console/uart.h, shared/start/start.S,
shared/startup/bspstart.c, shared/startup/setvec.c,
shared/timer/timer.c, shared/tsmac/dp83848phy.h,
shared/tsmac/tsmac.c, shared/tsmac/tsmac.h: New files.
