path: root/c/src/lib/libbsp/include/rtems (follow)
* Patch rtems-rc-20000709-1.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-07-104-0/+78
that addresses aspects of the targopts.h multilib related issues. Changes: * Move targopts.h to libbsp/include, because the current targopts.h actually is a per-BSP-header and therefore can not stay below exec/. * Introduce an autoheader generated header file (exec/score/include/rtems/score/cpuopts.h), which shall take per-cpu configuration options only. * Move all autoconf-detectable/configure specified per-cpu option-defines from targopts.h to cpuopts.h. * Add Makefiles to the libbsp/shared directory hierarchy. Notes: * The new per-bsp targopts.h in libbsp includes the per-cpu cpuopts.h. This way, the new targopts.h is kept backward compatible to the old targopts.h and existing BSPs which (carelessly) include targopts.h (i386, ppc) should be kept working when using the multilib-disabled configuration scheme. * cpuopts.h is not yet complete, because the per-BSP make-targopts rules from custom/<BSP>.cfg files can not be applied to files below exec/ when building multilibs. * All files below exec/ should not include targopts.h anymore, but should include cpuopts.h instead. However, eliminating inclusion of targopts.h currently triggers further structural / header file inclusion related issues, because several ports apply BSP or CPU_MODEL specific defines from targopts.h below exec/
