startup/Makefile.am, timer/Makefile.am, wrapup/Makefile.am,
start/Makefile.am: Include compile.am
* console/Makefile.am, start/Makefile.am, startup/Makefile.am,
wrapup/Makefile.am, clock/Makefile.am: Include compile.am
cpuopts.h.
exec/configure.in, only.
quoting bugs in autoconf).
formating changes :)
are now in libcpu. This required significant rework of the
score/cpu header files and the creation of multiple header files
and subdirectories in libcpu/i960.
again neither will unlinked executables. :)
<corsepiu@faw.uni-ulm.de> to add -qnolinkcmds to bsp_specs like
other BSPs.
have them.
from cvs by adding .cvsignore files.
by gdb 5.0's i960 simulator) is enough to run hello world.
that contains:
* Removes MKLIB
handling)
./bootstrap
converted to automake.
that contains:
regarded as bugs).
now works).
* removes libbsp/bare/wrapup
* Further cleanups
that converts the i960 directory to automake.
The same kind of libbsp configuration as for the mips64orion, now for
the i960.
In addition to libbsp configuration this patch also contains two fixes
for cvme961.cfg and rxgen960.cfg, which contained non-functional
make-exes. (Now both bsps probably have the same issues with linking c++
applications as the gensh2 has, but this is a different open issue not
tried to be solved now).
The rxgen961 also seems to have problems with its start file, because
linking apps fails due to not finding start.o. (Note that
libbsp/i960/rxgen960 lacks a start subdirectory!). I leave solving this
issue to you :)
Renamed file shmsupp/intr.c in some BSPs to shmsupp/cause_intr.c to
avoid conflict with rtems/src/intr.c (Classic API Interrupt Manager).
*.cfg files.
dependencies
automake and RTEMS make rules
convention)
performs automatically.
WARNING:
Makefile.ams.
autoconf/automake changes.
<mark@ramix.com> of RAMIX.
