* .cvsignore: Reformat.
Add autom4te*cache.
Remove autom4te.cache.
* shmsupp/Makefile.am: Use .$(OBJEXT) instead of .o.
Fix bsplib_DATA = $(PROJECT_RELEASE)/lib/rxgen_romld$(LIB_VARIANT).o.
Add bsplib_DATA = $(PROJECT_RELEASE)/lib/rxgen_romld$(LIB_VARIANT).o.
* wrapup/Makefile.am: Add $(LIB) to all-local.
* startup/linkcmds: In support of gcc 3.1, added one of more
of the sections .jcr, .rodata*, .data.*, .gnu.linkonce.s2.*,
.gnu.linkonce.sb2.*, and .gnu.linkonce.s.*. Spacing corrections
and direction of segments to memory regions may also have been
addressed. This was a sweep across all BSPs.
* startup/linkcmds.real: Ditto.
* clock/ckinit.c: Add volatile to Clock_driver_ticks.
* startup/nulsystbl.c: Fix braces.
* startup/Makefile.am: Remove types.h.
* startup/types.h: Remove.
* console/console.c: Remove NO_BSP_INIT, SERIAL_INPUT.
* timer: New subdirectory.
* timer/Makefile.am: New file.
* timer/.cvsignore: New file.
* Makefile.am: Modified to reflect above.
* configure.ac: Ditto.
* include/bsp.h: Stubs to let tm27 compile and link.
* include/zilog/Makefile.am: Remove.
* include/motorola/Makefile.am: Remove.
* include/sys/Makefile.am: Remove.
* include/Makefile.am: Handle subdirs, require automake-1.5
* console/console-io.c: Fixed typo.
* clock/ckinit.c, console/console.c, include/bsp.h, startup/bspstart.c,
startup/exit.c, startup/setvec.c, timer/timer.c, timer/timerisr.S:
Fixed typo.
* configure.in: Remove.
* acinclude.m4: New file.
* shmsupp/lock.c: Renamed delay() to rtems_bsp_delay().
* wrapup/Makefile: Use GENERIC_FILES = to make automake-1.5 happy.
* Removing non-function shmsupp directory.
* shmsupp/.cvsignore, shmsupp/Makefile.am, shmsupp/addrconv.c,
shmsupp/getcfg.c, shmsupp/lock.c, shmsupp/mpisr.c: Removed.
* configure.in, Makefile.am, wrapup/Makefile.am
* console/console-io.c: Added console_initialize_hardware().
* include/bsp.h: Removed incorrect error case.
startup/Makefile.am, timer/Makefile.am, wrapup/Makefile.am,
start/Makefile.am: Include compile.am
* console/Makefile.am, start/Makefile.am, startup/Makefile.am,
wrapup/Makefile.am, clock/Makefile.am: Include compile.am
