path: root/c/src/lib/libbsp/i960/rxgen960/Makefile.in (follow)
* Patch rtems-rc-19991117-4.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>:Joel Sherrill1999-11-221-1/+1
* Replaced Makefile.in's with modified copies of cvme961 to getJoel Sherrill1999-10-271-4/+19
| | | | autoconf/automake changes.
* The rxgen960 BSP and i960 RPM support was submitted by Mark BronsonJoel Sherrill1999-10-271-0/+16
<mark@ramix.com> of RAMIX.
