path: root/c/src/lib/libbsp/i960/cvme961/ChangeLog (follow)
* 2004-09-29 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2004-09-291-347/+0
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * .cvsignore, ChangeLog, Makefile.am, acinclude.m4, configure.ac, cvme961/.cvsignore, cvme961/ChangeLog, cvme961/Makefile.am, cvme961/bsp_specs, cvme961/configure.ac, cvme961/times, cvme961/clock/ckinit.c, cvme961/console/console.c, cvme961/include/.cvsignore, cvme961/include/bsp.h, cvme961/include/tm27.h, cvme961/shmsupp/addrconv.c, cvme961/shmsupp/getcfg.c, cvme961/shmsupp/lock.c, cvme961/shmsupp/mpisr.c, cvme961/start/start.S, cvme961/startup/bspclean.c, cvme961/startup/bspstart.c, cvme961/startup/exit.c, cvme961/startup/linkcmds, cvme961/startup/setvec.c, cvme961/timer/timer.c, cvme961/timer/timerisr.S, i960sim/.cvsignore, i960sim/ChangeLog, i960sim/Makefile.am, i960sim/bsp_specs, i960sim/configure.ac, i960sim/clock/clockdrv.c, i960sim/console/console-io.c, i960sim/console/mon-syscalls.S, i960sim/include/.cvsignore, i960sim/include/bsp.h, i960sim/include/tm27.h, i960sim/start/start.c, i960sim/startup/bspstart.c, i960sim/startup/linkcmds, rxgen960/.cvsignore, rxgen960/ChangeLog, rxgen960/Makefile.am, rxgen960/README, rxgen960/bsp_specs, rxgen960/configure.ac, rxgen960/clock/ckinit.c, rxgen960/console/concntl.h, rxgen960/console/console.c, rxgen960/console/serial.c, rxgen960/console/serial.h, rxgen960/include/.cvsignore, rxgen960/include/bsp.h, rxgen960/include/rxgen960_config.h, rxgen960/include/tm27.h, rxgen960/start/rxgen_romld.S, rxgen960/startup/asmfault.S, rxgen960/startup/asmfault.h, rxgen960/startup/asmstub.S, rxgen960/startup/asmstub.h, rxgen960/startup/bspstart.c, rxgen960/startup/cntrltbl.c, rxgen960/startup/cntrltbl.h, rxgen960/startup/dram.ld, rxgen960/startup/exit.c, rxgen960/startup/fault.c, rxgen960/startup/fault.h, rxgen960/startup/faultret.h, rxgen960/startup/flttbl.c, rxgen960/startup/flttbl.h, rxgen960/startup/frmstr.c, rxgen960/startup/frmstr.h, rxgen960/startup/i960.h, rxgen960/startup/ihandler.S, rxgen960/startup/ihandler.h, rxgen960/startup/intrtbl.c, rxgen960/startup/intrtbl.h, rxgen960/startup/kkprintf.c, rxgen960/startup/linkcmds, rxgen960/startup/linkcmds.real, rxgen960/startup/main.h, rxgen960/startup/memchnl.h, rxgen960/startup/nmi.c, rxgen960/startup/nulsystbl.c, rxgen960/startup/pmc901_memmap.h, rxgen960/startup/prcb.c, rxgen960/startup/prcb.h, rxgen960/startup/rom.ld, rxgen960/startup/rom_cntrltbl.c, rxgen960/startup/rom_ibr.c, rxgen960/startup/rom_ibr.h, rxgen960/startup/rom_prcb.c, rxgen960/startup/rommon.h, rxgen960/startup/sctns.c, rxgen960/startup/sctns.h, rxgen960/startup/setvec.c, rxgen960/startup/systbl.c, rxgen960/startup/systbl.h, rxgen960/startup/time.h, rxgen960/timer/timer.c, rxgen960/timer/timerisr.S: Removed.
* 2004-09-24 Ralf Corsepius <ralf_corsepius@rtems.org>Ralf Corsepius2004-09-241-0/+4
| | | | * configure.ac: Require automake > 1.9.
* 2004-04-23 Ralf Corsepius <ralf_corsepius@rtems.org>Ralf Corsepius2004-04-231-0/+6
| | | | | | PR 610/bsps * Makefile.am: Add include/tm27.h, Cosmetics. * include/tm27.h: Final cosmetics.
* 2004-04-22 Ralf Corsepius <ralf_corsepius@rtems.org>Ralf Corsepius2004-04-221-0/+5
| | | | | * include/bsp.h: Split out tmtest27 support. * include/tm27.h: New.
* 2004-04-21 Ralf Corsepius <ralf_corsepius@rtems.org>Ralf Corsepius2004-04-211-0/+5
| | | | | PR 613/bsps * include/bsp.h: Remove MAX_LONG_TEST_DURATION.
| | | | | PR 614/bsps * include/bsp.h: Remove MAX_SHORT_TEST_DURATION (Unused).
* * cvme961/timer/timer.c: Include <rtems/zilog/z8536.h> instead ofRalf Corsepius2004-04-081-0/+4
| | | | <zilog/z8536.h>.
* * start/start.S: Include <rtems/asm.h> instead of <asm.h>.Ralf Corsepius2004-04-021-0/+5
| | | | * timer/timerisr.S: Include <rtems/asm.h> instead of <asm.h>.
* 2004-04-01 Ralf Corsepius <ralf_corsepius@rtems.org>Ralf Corsepius2004-04-011-0/+6
| | | | | | * include/bsp.h: Include <rtems/clockdrv.h> instead of <clockdrv.h>. * include/bsp.h: Include <rtems/console.h> instead of <console.h>. * include/bsp.h: Include <rtems/iosupp.h> instead of <iosupp.h>.
* 2004-03-31 Ralf Corsepius <ralf_corsepius@rtems.org>Ralf Corsepius2004-03-311-0/+7
| | | | | | | * clock/ckinit.c, include/bsp.h, shmsupp/addrconv.c, shmsupp/getcfg.c, shmsupp/lock.c, shmsupp/mpisr.c, startup/bspstart.c, timer/timer.c: Convert to using c99 fixed size types.
* 2004-02-19 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-02-191-0/+5
| | | | | * Makefile.am: Reflect changes to bsp.am. Preinstall dist_project_lib*.
* 2004-02-14 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-02-141-0/+4
* 2004-02-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-02-121-0/+4
| | | | * Makefile.am: Use CPPASCOMPILE instead of CCASCOMPILE.
* 2004-02-02 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-02-021-0/+4
| | | | * Makefile.am: Correct path to libcpu.
* 2004-02-02 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-02-021-0/+10
| | | | | | | | | | * Makefile.am: Merge-in clock/Makefile.am, console/Makefile.am, shmsupp/Makefile.am, start/Makefile.am, startup/Makefile.am, timer/Makefile.am, wrapup/Makefile.am. Use automake compilation rules. * clock/Makefile.am, console/Makefile.am, shmsupp/Makefile.am, start/Makefile.am, startup/Makefile.am, timer/Makefile.am, wrapup/Makefile.am: Remove. * configure.ac: Reflect changes above.
* 2004-01-28 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-291-0/+5
| | | | | * configure.ac: Add nostdinc to AUTOMAKE_OPTIONS. Add RTEMS_PROG_CCAS.
* 2004-01-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-211-0/+5
| | | | | * Makefile.am: Add PREINSTALL_DIRS. * wrapup/Makefile.am: Reflect changes to libcpu.
* 2004-01-14 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-141-0/+6
| | | | | | * start/Makefile.am: Re-add dirstamps to PRE/TMPINSTALL_FILES. Add PRE/TMPINSTALL_FILES to CLEANFILES. * startup/Makefile.am: Ditto.
* 2004-01-05 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-051-0/+5
| | | | | * wrapup/Makefile.am: Eliminate $(LIB). Use noinst_DATA to trigger building libbsp.a.
* 2003-12-18 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-12-181-0/+4
| | | | * wrapup/Makefile.am: Remove GENERIC_FILES.
* 2003-12-13 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-12-131-0/+5
| | | | | * start/Makefile.am: s,${PROJECT_RELEASE}/lib,$(PROJECT_LIB),g. * startup/Makefile.am: s,${PROJECT_RELEASE}/lib,$(PROJECT_LIB),g.
* 2003-12-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-12-121-0/+5
| | | | | * start/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES. * startup/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* 2003-12-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-12-121-0/+4
| | | | * configure.ac: Require automake >= 1.8, autoconf >= 2.59.
* 2003-12-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-12-091-0/+6
| | | | | | * start/Makefile.am: Misc cleanups and fixes. * startup/Makefile.am: Misc cleanups and fixes. * wrapup/Makefile.am: Misc cleanups and fixes.
* 2003-12-03 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-12-031-0/+10
| | | | | | | | | | * Makefile.am: Add preinstallation dirstamp support. * clock/Makefile.am: Cosmetics. * console/Makefile.am: Cosmetics. * shmsupp/Makefile.am: Cosmetics. * startup/Makefile.am: Cosmetics. * timer/Makefile.am: Cosmetics. * wrapup/Makefile.am: Cosmetics.
* 2003-12-02 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-12-021-0/+10
| | | | | | | | | | * clock/Makefile.am: Remove all-local: $(ARCH). * console/Makefile.am: Remove all-local: $(ARCH). * shmsupp/Makefile.am: Remove all-local: $(ARCH). * start/Makefile.am: Remove all-local: $(ARCH). * startup/Makefile.am: Remove all-local: $(ARCH). * timer/Makefile.am: Remove all-local: $(ARCH). * wrapup/Makefile.am: Remove all-local: $(ARCH).
* 2003-09-29 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-09-291-0/+7
| | | | | | | * Makefile.am: Merge-in include/Makefile.am. Reflect changes to bsp.am. * include/Makefile.am: Remove. * configure.ac: Reflect changes above.
* 2003-09-24 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-09-241-0/+4
| | | | * bsp_specs: Remove *lib:.
* 2003-09-04 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-09-041-0/+8
| | | | | | | | * clock/ckinit.c, console/console.c, include/bsp.h, shmsupp/addrconv.c, shmsupp/getcfg.c, shmsupp/lock.c, shmsupp/mpisr.c, start/start.S, startup/bspclean.c, startup/bspstart.c, startup/exit.c, startup/linkcmds, startup/setvec.c, timer/timer.c, timer/timerisr.S: URL for license changed.
* 2003-08-18 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-08-181-0/+4
| | | | * Makefile.am: Reflect having moved aclocal/.
* Fix broken ChangeLog entries.Ralf Corsepius2003-08-181-9/+9
* 2003-08-16 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-08-161-0/+12
| | | | | | | | | | | | Makefile.am: Reflect having moved automake. clock/Makefile.am: Reflect having moved automake. console/Makefile.am: Reflect having moved automake. include/Makefile.am: Reflect having moved automake. shmsupp/Makefile.am: Reflect having moved automake. start/Makefile.am: Reflect having moved automake. startup/Makefile.am: Reflect having moved automake. timer/Makefile.am: Reflect having moved automake. wrapup/Makefile.am: Reflect having moved automake.
* Correcting to include PR numbers.Joel Sherrill2003-08-141-0/+1
* 2003-08-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-08-111-0/+4
| | | | * configure.ac: Use rtems-bugs@rtems.com as bug report email address.
* 2003-08-06 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-08-061-0/+5
| | | | | * bsp_specs: Remove -D__embedded__ -Asystem(embedded) from cpp. Remove cpp, old_cpp (now unused).
* Merger from rtems-4-6-branch.Ralf Corsepius2003-03-111-0/+4
* 2003-02-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-02-111-0/+4
| | | | * configure.ac: AM_INIT_AUTOMAKE([1.7.2]).
| | | | * configure.ac: AC_PREREQ(2.57).
* 2003-01-15 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-01-151-0/+9
| | | | | | | | | * clock/Makefile.am: Don't include @RTEMS_BSP@.cfg. * console/Makefile.am: Don't include @RTEMS_BSP@.cfg. * shmsupp/Makefile.am: Don't include @RTEMS_BSP@.cfg. * start/Makefile.am: Don't include @RTEMS_BSP@.cfg. * startup/Makefile.am: Don't include @RTEMS_BSP@.cfg. * timer/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* 2002-12-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-12-121-0/+4
| | | | * start/Makefile.am: Use install-data-local to install startfile.
* 2002-12-10 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-12-101-0/+4
| | | | * wrapup/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* 2002-10-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-10-211-0/+6
| | | | | | * .cvsignore: Reformat. Add autom4te*cache. Remove autom4te.cache.
* 2002-08-21 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-08-211-0/+4
| | | | * bsp_specs: Added support for -nostdlibs.
* 2002-08-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-08-111-0/+10
| | | | | | | | | | * clock/Makefile.am: Use .$(OBJEXT) instead of .o. * console/Makefile.am: Use .$(OBJEXT) instead of .o. * shmsupp/Makefile.am: Use .$(OBJEXT) instead of .o. * start/Makefile.am: Use .$(OBJEXT) instead of .o. * startup/Makefile.am: Use .$(OBJEXT) instead of .o. * timer/Makefile.am: Use .$(OBJEXT) instead of .o. * wrapup/Makefile.am: Use .$(OBJEXT) instead of .o.
* 2002-07-20 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-07-211-0/+5
| | | | | * start/Makefile.am: Eliminate PGM. Add bsplib_DATA = $(PROJECT_RELEASE)/lib/start$(LIB_VARIANT).o.
* 2002-07-19 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-07-191-0/+4
| | | | * startup/Makefile.am: Add bsplib_DATA = linkcmds.
* 2002-07-04 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-07-041-0/+5
| | | | | * wrapup/Makefile.am: Eliminate TMPINSTALL_FILES. Remove $(OBJS) from all-local.
* 2002-07-04 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-07-041-0/+4
| | | | * wrapup/Makefile.am: Add $(LIB) to all-local.
* 2002-06-29 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-06-301-0/+4
| | | | * wrapup/Makefile.am: Remove preinstallation of libbsp.a,
* 2001-05-09 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-05-091-0/+8
| | | | | | | | * startup/linkcmds: In support of gcc 3.1, added one of more of the sections .jcr, .rodata*, .data.*, .gnu.linkonce.s2.*, .gnu.linkonce.sb2.*, and .gnu.linkonce.s.*. Spacing corrections and direction of segments to memory regions may also have been addressed. This was a sweep across all BSPs.
