* | 2000-11-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2000-11-09 | 1 | -1/+1 |
| | | | | * Makefile.am: Use ... instead of RTEMS_TOPdir in ACLOCAL_AMFLAGS. | ||||
* | 2000-11-02 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2000-11-02 | 1 | -1/+1 |
| | | | | * Makefile.am: Switch to ACLOCAL_AMFLAGS = -I $(RTEMS_TOPdir)/aclocal. | ||||
* | 2000-10-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2000-10-27 | 1 | -1/+1 |
| | | | | | * Makefile.am: ACLOCAL_AMFLAGS= -I $(RTEMS_TOPdir)/macros. Switch to GNU canonicalization. | ||||
* | Merged from 4.5.0-beta3a | Joel Sherrill | 2000-06-12 | 1 | -2/+2 |
* | Patch rtems-rc-20000104-6.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2000-01-10 | 1 | -0/+12 |
that converts the i960 directory to automake. The same kind of libbsp configuration as for the mips64orion, now for the i960. In addition to libbsp configuration this patch also contains two fixes for cvme961.cfg and rxgen960.cfg, which contained non-functional make-exes. (Now both bsps probably have the same issues with linking c++ applications as the gensh2 has, but this is a different open issue not tried to be solved now). The rxgen961 also seems to have problems with its start file, because linking apps fails due to not finding start.o. (Note that libbsp/i960/rxgen960 lacks a start subdirectory!). I leave solving this issue to you :) |
