path: root/c/src/lib/libbsp/i386 (follow)
* 2001-09-27 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-09-286-3/+15
| | | | * include/bsp.h: Renamed delay() to rtems_bsp_delay().
* 2001-09-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-09-274-2/+10
| | | | * include/Makefile.am: Use 'PREINSTALL_FILES ='.
* 2001-09-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-09-274-3/+9
| | | | | | * irq/Makefile.am: Use 'PREINSTALL_FILES ='. * comm/Makefile.am: Use 'PREINSTALL_FILES ='. * pci/Makefile.am: Use 'PREINSTALL_FILES ='.
* 2001-09-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-09-272-1/+5
| | | | * Makefile.am: Use 'PREINSTALL_FILES ='.
* 2001-09-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-09-274-4/+11
| | | | | | | * include/Makefile.am: Use 'CLEANFILES ='. * include/Makefile.am: Use 'PREINSTALL_FILES ='. * console/Makefile.am: Use 'PREINSTALL_FILES ='. * Makefile.am: Use 'TMPINSTALL_FILES ='.
* 2001-08-16 Mike Siers <mikes@poliac.com>Joel Sherrill2001-08-163-4/+20
| | | | * comm/tty_drv.c, comm/uart.c: Correct some minor cut and paste bugs.
* 2001-07-03 Mike Seirs <mike@poliac.com>Joel Sherrill2001-07-034-148/+179
| | | | | | | | | | | * comm/tty_drv.c, comm/uart.c, comm/uart.h: Adds the capability to use task driven serial I/O to ti386 BSPs. This patch leaves thex default I/O mode to be IRQ. If you want to use task I/O mode, then the tty_drv.c file needs to be modified. Basically, all you need to change is the data values of the termios callbacks structure. This callback structure is used in the tty1_open and tty2_open functions. The values you need to set are commented out in the source code.
* 2001-06-19 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-06-203-1/+7
| | | | | * console/Makefile.am: Remove RTEMS_H_FILES. * start/start16.S: include <bspopts.h> to get NEW_GAS.
* 2001-06-19 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-06-195-14/+18
| | | | | | | * comm/Makefile.am: Use *_HEADERS instead of *H_FILES. * io/Makefile.am: Ditto. * irq/Makefile.am: Ditto. * pci/Makefile.am: Ditto.
* 2001-06-19 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-06-197-12/+28
| | | | | | | | | * configure.in: Add bspopts.h. * include/.cvsignore: Add bspopts.h*, stamp-h*. * include/Makefile.am: Use *_HEADERS instead of *H_FILES. * 3c509/Makefile.am: Dito. * console/Makefile.am: Dito. * include/bsp.h: Include bspopts.h.
* 2001-05-26 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-06-146-4/+18
| | | | | | | * configure.in: Add bspopts.h. * include/.cvsignore: Add bspopts.h*, stamp-h*. * include/Makefile.am: Use *_HEADERS instead of *H_FILES. * include/bsp.h: Include bspopts.h.
* 2001-05-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-05-247-8/+23
| | | | | | | | | * configure.in: Add bspopts.h. * include/bsp.h: Include bspopts.h. * include/.cvsignore: Add bspopts.h*, stamp-h*. * include/Makefile.am: Use *_HEADERS instead of *H_FILES. * start/Makefile.am: Dito. * network/Makefile.am: Dito.
* 2001-05-10 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-05-116-3/+15
| | | | * configure.in: Use RTEMS_PROG_CC_FOR_TARGET([-ansi -fasm]).
* 2001-05-07 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-05-082-2/+4
| | | | * ne2000/ne2000.c: Remove #define __INSIDE_RTEMS_BSD_TCPIP_STACK__.
* 2001-01-08 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-01-081-0/+5
| | | | | * console/vt.c: Added include of <rtems.h> so _CPU_ISR_disable would be visible.
* 2001-01-05 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-01-051-0/+1
* 2000-12-05 Eric Valette <valette@crf.canon.fr>Joel Sherrill2000-12-059-128/+470
| | | | | | | | | | | | | * console/inch.c, console/keyboard.c, console/pc_keyb.c, console/vt.c, include/bsp.h: Correct incorrect interrupt level handling in new keyboard management code. Correct BSP_poll_char initialization routine. * start/start.S, startup/bspstart.c: Correct when the video is initialized. * timer/timer.c (Calibrate_1ms_loop): Address problem where this did not work correctly on all PC speeds. The new calibrate routine has been tested on Pentium 166, pentium II 200, pentium III 300 Mhz and does work as expected.
* 2000-12-05 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-12-051-0/+5
| | | | | * pc386/console/console.c, pc386/console/serial_mouse.c, pc386/console/vgainit.c, shared/comm/tty_drv.c: Remove warnings.
* Correct incorrect placement of last ChangeLog entry.Joel Sherrill2000-12-051-5/+0
* 2000-12-01 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-12-055-138/+158
* 2000-11-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-11-0912-6/+30
* 2000-11-02 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-11-0212-6/+30
* 2000-11-01 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-11-016-5/+24
| | | | | | | * startup/bspstart.c: assoc.h, error.h, libio_.h, libio.h, and libcsupport.h moved from libc to lib/include/rtems and now must be referenced as <rtems/XXX.h>. Header file order was cleaned up while doing this.
* 2000-10-29 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-10-292-51/+4
| | | | * startup/sbrk.c: Removed. Redundant with shared version.
* 2000-10-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-10-274-2/+12
* 2000-10-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-10-2710-6/+30
| | | | | * configure.in, Makefile.am: ACLOCAL_AMFLAGS= -I $(RTEMS_TOPdir)/macros. Switch to GNU canonicalization.
* 2000-10-23 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-10-232-2/+11
| | | | * console/serial_mouse.c: Fixed typos introduced by removal of CR/LF.
* 2000-10-20 Rosimildo da Silva <rdasilva@connecttel.com>Joel Sherrill2000-10-202-37/+42
| | | | * console/serial_mouse.c: Added support for changing serial parameters.
* 2000-10-20 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-10-202-1/+6
| | | | | * console/console.c: Invoke BSP_uart_init() with enough arguments now that more communication parameters are settable.
* 2000-10-20 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-10-203-1/+17
| | | | | | * include/wd80x3.h: Added file header and logic to prevent multiple inclusions of this file. * wd8003/wd8003.c: Corrected attach to include "int attach" parameter.
* 2000-10-20 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-10-202-10/+54
| | | | * include/bsp.h: Cleaned up network driver name and attach defines.
* 2000-10-20 Dmitry Kargapolov <dk@gentex.ru>Joel Sherrill2000-10-201-163/+385
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * ne2000/ne2000.c: Fix some errors in the driver. 1. There was no sufficient check of data in ethernet header. The code in ne_rx_daemon() was: inport_word (dport, len); ... len -= 4; ... if (len > 0) ne_read_data (sc, startaddr, len, p); Unfortunately, sometimes my NIC gave me too big len value, the result was memory override. To fix this, I added ethernet header data checking. 2. The way overrides were serviced was not good. It was complex but sometimes did not provide reliable continuing of NIC working. I had the situation of an endless loop in ne_check_status() after override processing. 3. There was conceptual error of porting. The old method of overrides curing was ported from the OS-s, where override-processing did start immediately. But RTEMS-version uses events, and cleaning of the overrides can start later. I selected the way of ne2000 programming that is used in freebsd kernel (v4.0). Because of both problems, incorrect data in header of raw packet and receiver override, it went through ne_reset() and fully reset the ne2000. So, in summary - added detecting of the incorrect data in ethernet header; - replaced handling of receiver overrides with new scheme, via resetting of NIC, this method is used also in case of invalid header detecting.
* 2000-10-19 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-10-192-1/+6
| | | | | * console/console.c: Invoke BSP_uart_init() with all arguments now that it takes more parameters.
* 2000-10-19 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-10-192-0/+5
| | | | * common/uart.h: Added prototype for BSP_uart_set_baud().
* 2000-10-18 Charles-Antoine Gauthier <charles.gauthier@nrc.ca>Joel Sherrill2000-10-192-1/+26
| | | | * comm/uart.c (BSP_uart_init): Save more line state parameters.
* 2000-10-18 Charles-Antoine Gauthier <charles.gauthier@nrc.ca>Joel Sherrill2000-10-185-14/+86
| | | | | | * comm/i386-stub-glue.c, comm/tty_drv.c, comm/uart.c, comm/uart.h: Add the ability to set parity, number of data bits and number of stop bits to the existing i386 serial drivers.
* 2000-10-18 Charles-Antoine Gauthier <charles.gauthier@nrc.ca>Joel Sherrill2000-10-184-5/+80
| | | | | | * console/console.c, console/serial_mouse.c, include/bsp.h: Add the ability to set parity, number of data bits and number of stop bits to the existing i386 serial drivers.
* 2000-10-17 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-10-172-2/+7
| | | | | * irq/Makefile.am, irq/idt.c: Added idt.c since it has been moved libcpu/i386 to libbsp/i386/shared/irq.
* 2000-10-17 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-10-176-4/+19
| | | | | * startup/Makefile.am: Added idt.c since it has been moved libcpu/i386 to libbsp/i386/shared/irq.
* 2000-09-29 Charles-Antoine Gauthier <charles.gauthier@nrc.ca>Joel Sherrill2000-09-296-1/+142
| | | | | | * startup/linkcmds: Added lines so DWARF debug information would be available. Otherwise gdb complains that the offsets for the debug info are incorrect and doesn't load the files.
* 2000-09-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-09-123-7/+5
| | | | | * start/Makefile.am: Remove AM_CPPFLAGS and GAS_CODE16 conditional. * startup/Makefile.am: Cleanup comments.
* 2000-09-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-09-124-8/+8
* 2000-09-04 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-09-052-2/+6
| | | | * io/Makefile.am: Formatting.
* 2000-09-04 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-09-0516-2/+28
| | | | | | * clock/Makefile.am, console/Makefile.am, network/Makefile.am, start/Makefile.am, startup/Makefile.am, timer/Makefile.am, wrapup/Makefile.am: Include compile.am
* 2000-09-04 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-09-0510-3/+18
| | | | | | | * 3c509/Makefile.am, clock/Makefile.am, console/Makefile.am, ne2000/Makefile.am, start/Makefile.am, startup/Makefile.am, timer/Makefile.am, wd8003/Makefile.am, wrapup/Makefile.am: Include compile.am
* 2000-08-30 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-08-302-12/+50
| | | | | * console/keyboard.h: Changed numerous routines from extern inline to static inline.
* 2000-08-26 Rosimildo da Silva <rdasilva@connecttel.com>Joel Sherrill2000-08-307-9/+737
| | | | | | | | | | | | * shared/comm: Added "/dev/ttyS1" & "/dev/ttyS2" support for the i386 BSPs. * shared/comm/gdb_glue.c: New file. * shared/comm/i386_io.c: New file. * shared/comm/tty_drv.c: New file. * shared/comm/tty_drv.h: New file. * shared/comm/Makefile.am: Account for new files. * shared/comm/uart.c: Adds support for sending characters to another "line discipline."
* 2000-08-26 Rosimildo da Silva <rdasilva@connecttel.com>Joel Sherrill2000-08-3023-351/+6182
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * Major rework of the "/dev/console" driver. * Added termios support for stdin ( keyboard ). * Added ioctls() to support modes similar to Linux( XLATE, RAW, MEDIUMRAW ). * Added Keyboard mapping and handling of the keyboard's leds. * Added Micro FrameBuffer driver ( "/dev/fb0" ) for bare VGA controller ( 16 colors ). * Added PS/2 and Serial mouse support for PC386 BSP. * console/defkeymap.c: New file. * console/fb_vga.c: New file. * console/fb_vga.h: New file. * console/i386kbd.h: New file. * console/kd.h: New file. * console/keyboard.c: New file. * console/keyboard.h: New file. * console/mouse_parser.c: New file. * console/mouse_parser.h: New file. * console/pc_keyb.c: New file. * console/ps2_drv.h: New file. * console/ps2_mouse.c: New file. * console/ps2_mouse.h: New file. * console/serial_mouse.c: New file. * console/serial_mouse.h: New file. * console/vgainit.c: New file. * console/vt.c: New file. * console/Makefile.am: Reflect new files. * console/console.c, console/inch.c, console/outch.c: Console functionality modifications. * startup/Makefile.am: Pick up tty_drv.c and gdb_glue.c
* Adding ChangeLogs.Joel Sherrill2000-08-107-0/+20
* Fix typo.Joel Sherrill2000-06-141-1/+1
