Update #3408.
Close #3410.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
system. Since all content of
makes no sense to keep it.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #2408.
Update #3285.
Update #3285.
Update #3387.
Update #3285.
Update #3285.
Update #3285.
This was used by the not supported "make dist".
Update #3285.
Update #3285.
Update #3285.
upgrade to that version.
Close #3387.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
When it's a macro, a function declaration causes a compiler error due to the
macro being expanded.
Partial log showing error:
https://gist.github.com/AmaanC/ab3521141479aa6f61ea25f5d74ebb4d
Closes #3331
With HAS_SMP set, we have:
libbsp_a_LIBADD += appstart.$(OBJEXT)
When trying to build appstart.o, however, we link start.o with appcpustart.o
through the linkcmds script, which leaves several symbols unresolved, and
without the "-r" (or -i) flag, this throws undefined reference errors.
This change requires us to re-run the ./bootstrap script to regenerate
Makefile.in, and therefore the Makefile for the particular BSP as well.
Complete log of errors available here:
https://gist.github.com/AmaanC/d40bd7393dca1f82965938275845b7f9
Updates #3331
* bsps/shared/cache
Update #3285.
line option.
may suppress warnings.
erc32, imx, qoriq, etc.
* cpukit/include
* cpukit/libnetworking
* bsps/include
* bsps/@RTEMS_CPU@/include
order.
Update #3254.
This header is used also by the motorola_powerpc BSP.
Update #3254.
Update #3254.
The name suggests that this is a private implementation header file.
Update #3254.
Update #3254.
