PR 608/bsps
* pci/pcibios.c: BusCountPCI().
* startup/linkcmds: Add gnu.linkonce.d and gcc_except_table sections.
* Makefile.am: Add -D__INSIDE_RTEMS_BSD_TCPIP_STACK__ for network.
* network/ne2000.c: Add include of <sys/errno.h>.
* 3c509/3c509.c: Add <sys/errno.h>.
* startup/linkcmds: Add .jcr section.
* PR 624/bsps
startup/bspstart.c: When probing the memory, make sure not to
corrupt the application. Only probe addresses beyond rtemsFreeMemStart.
* Let IBMPC_outch() convert LF -> CRLF to avoid printk scrambling
the screen.
* ne2000/ne2000.c, wd8003/wd8003.c: Include errno.h as a consequence of
recent updates to BSD header files.
PR 610/bsps
* Makefile.am: Add include/tm27.h, Cosmetics.
* include/tm27.h: Final cosmetics.
* include/tm27.h: New.
PR 613/bsps
PR 614/bsps
* configure.ac: Add RTEMS_ROOT (HACK: This is the last file c/src
which still uses RTEMS_ROOT).
* irq/irq_asm.S: Include <rtems/asm.h> instead of <asm.h>.
* timer/timerisr.S: Include <rtems/asm.h> instead of <asm.h>.
* startup/ldsegs.S: Include <rtems/asm.h> instead of <asm.h>.
* network/network.c: Include <rtems/asm.h> instead of <asm.h>.
* pci/pcibios.c: Convert to using c99 fixed size types.
* clock/ckinit.c, include/bsp.h, startup/bspstart.c, timer/timer.c:
* clock/ckinit.c, clock/rtc.c, console/inch.c, ide/ide.c,
include/bsp.h, startup/bspstart.c, timer/timer.c: Convert to using
* clock/ckinit.c, clock/rtc.c, include/bsp.h, startup/bspstart.c,
timer/timer.c: Convert to using c99 fixed size types.
* Makefile.am: Reflect changes to bsp.am.
Preinstall dist_project_lib*.
* Makefile.am: Don't install *.rels. Reflect changes to bsp.am.
* configure.ac: Explicitly check for OBJCOPY.
* acinclude.m4: Regenerate.
* configure.ac: RTEMS_CHECK_BSPDIR([$RTEMS_BSP_FAMILY]).
* Makefile.am: Use CPPASCOMPILE instead of CCASCOMPILE.
* Makefile.am: Add start*.bin to CLEANFILES.
* Makefile.am: Split startup into multiple .rels without reorganizing
the source.
* Makefile.am: Pickup files from ../../i386/shared instead of
../shared. Reformat.
* Makefile.am: Add missing $ in reference to 3c509.rel.
* Makefile.am: Merge-in 3c509/Makefile.am, clock/Makefile.am,
console/Makefile.am, ide/Makefile.am, ne2000/Makefile.am,
startup/Makefile.am, timer/Makefile.am, wd8003/Makefile.am,
wrapup/Makefile.am. Use automake compilation rules.
* 3c509/Makefile.am, clock/Makefile.am, console/Makefile.am,
ide/Makefile.am, ne2000/Makefile.am, startup/Makefile.am,
timer/Makefile.am, wd8003/Makefile.am, wrapup/Makefile.am: Remove.
* start/start.S: Change comment to make it gcc -ansi compliant.
* irq/irq_asm.S: Convert #..-comments to /*..*/ comments.
* Makefile.am: Merge-in debug_ada/Makefile.am, debug_c/Makefile.am,
dos_sup/Makefile.am, network_ada/adasockets/Makefile.am,
network_ada/Makefile.am, network_ada/listener/Makefile.am,
network_ada/tcprelay/Makefile.am, ts_1325_ada/Makefile.am. Use automake
compilation rules.
* debug_ada/Makefile.am, debug_c/Makefile.am, dos_sup/Makefile.am,
network_ada/adasockets/Makefile.am, network_ada/Makefile.am,
network_ada/listener/Makefile.am, network_ada/tcprelay/Makefile.am,
ts_1325_ada/Makefile.am: Remove.
network/Makefile.am, startup/Makefile.am, timer/Makefile.am,
* clock/Makefile.am, console/Makefile.am, network/Makefile.am,
startup/Makefile.am, timer/Makefile.am, wrapup/Makefile.am: Remove.
* configure.ac: Add nostdinc to AUTOMAKE_OPTIONS.
Add RTEMS_PROG_CCAS.
* console/Makefile.am: Add PREINSTALL_DIRS.
* wrapup/Makefile.am: Reflect changes to libcpu.
* startup/Makefile.am: Ditto.
