* startup/sbrk.c: Removed. Redundant with shared version.
* configure.in, Makefile.am: ACLOCAL_AMFLAGS= -I $(RTEMS_TOPdir)/macros.
* console/serial_mouse.c: Fixed typos introduced by removal of CR/LF.
* console/serial_mouse.c: Added support for changing serial parameters.
* console/console.c: Invoke BSP_uart_init() with enough arguments
now that more communication parameters are settable.
* include/wd80x3.h: Added file header and logic to prevent multiple
inclusions of this file.
* wd8003/wd8003.c: Corrected attach to include "int attach" parameter.
* include/bsp.h: Cleaned up network driver name and attach defines.
* ne2000/ne2000.c: Fix some errors in the driver.
1. There was no sufficient check of data in ethernet header.
The code in ne_rx_daemon() was:
inport_word (dport, len);
len -= 4;
if (len > 0)
ne_read_data (sc, startaddr, len, p);
Unfortunately, sometimes my NIC gave me too big len value,
the result was memory override. To fix this, I added ethernet
header data checking.
2. The way overrides were serviced was not good. It was complex
but sometimes did not provide reliable continuing of NIC working.
I had the situation of an endless loop in ne_check_status()
after override processing.
3. There was conceptual error of porting. The old method of
overrides curing was ported from the OS-s, where override-processing
did start immediately. But RTEMS-version uses events, and cleaning
of the overrides can start later.
I selected the way of ne2000 programming that is used
in freebsd kernel (v4.0).
Because of both problems, incorrect data in header of raw packet
and receiver override, it went through ne_reset() and fully
reset the ne2000.
So, in summary
- added detecting of the incorrect data in ethernet header;
- replaced handling of receiver overrides with new scheme,
via resetting of NIC, this method is used also in case of
invalid header detecting.
* console/console.c: Invoke BSP_uart_init() with all arguments
now that it takes more parameters.
* common/uart.h: Added prototype for BSP_uart_set_baud().
* comm/uart.c (BSP_uart_init): Save more line state parameters.
* comm/i386-stub-glue.c, comm/tty_drv.c, comm/uart.c, comm/uart.h:
Add the ability to set parity, number of data bits and
number of stop bits to the existing i386 serial drivers.
* console/console.c, console/serial_mouse.c, include/bsp.h:
* irq/Makefile.am, irq/idt.c: Added idt.c since it has been moved
libcpu/i386 to libbsp/i386/shared/irq.
* startup/Makefile.am: Added idt.c since it has been moved libcpu/i386
* startup/linkcmds: Added lines so DWARF debug information
would be available. Otherwise gdb complains that the offsets
for the debug info are incorrect and doesn't load the files.
* start/Makefile.am: Remove AM_CPPFLAGS and GAS_CODE16 conditional.
* startup/Makefile.am: Cleanup comments.
* io/Makefile.am: Formatting.
* clock/Makefile.am, console/Makefile.am, network/Makefile.am,
* 3c509/Makefile.am, clock/Makefile.am, console/Makefile.am,
ne2000/Makefile.am, start/Makefile.am, startup/Makefile.am,
timer/Makefile.am, wd8003/Makefile.am, wrapup/Makefile.am: Include
compile.am
* console/keyboard.h: Changed numerous routines from extern inline
to static inline.
* shared/comm: Added "/dev/ttyS1" & "/dev/ttyS2" support for
the i386 BSPs.
* shared/comm/gdb_glue.c: New file.
* shared/comm/i386_io.c: New file.
* shared/comm/tty_drv.c: New file.
* shared/comm/tty_drv.h: New file.
* shared/comm/Makefile.am: Account for new files.
* shared/comm/uart.c: Adds support for sending characters to
another "line discipline."
* Major rework of the "/dev/console" driver.
* Added termios support for stdin ( keyboard ).
* Added ioctls() to support modes similar to Linux( XLATE,
RAW, MEDIUMRAW ).
* Added Keyboard mapping and handling of the keyboard's leds.
* Added Micro FrameBuffer driver ( "/dev/fb0" ) for bare VGA
controller ( 16 colors ).
* Added PS/2 and Serial mouse support for PC386 BSP.
* console/defkeymap.c: New file.
* console/fb_vga.c: New file.
* console/fb_vga.h: New file.
* console/i386kbd.h: New file.
* console/kd.h: New file.
* console/keyboard.c: New file.
* console/keyboard.h: New file.
* console/mouse_parser.c: New file.
* console/mouse_parser.h: New file.
* console/pc_keyb.c: New file.
* console/ps2_drv.h: New file.
* console/ps2_mouse.c: New file.
* console/ps2_mouse.h: New file.
* console/serial_mouse.c: New file.
* console/serial_mouse.h: New file.
* console/vgainit.c: New file.
* console/vt.c: New file.
* console/Makefile.am: Reflect new files.
* console/console.c, console/inch.c, console/outch.c: Console
functionality modifications.
* startup/Makefile.am: Pick up tty_drv.c and gdb_glue.c
location in libc.
that contains:
* Removes MKLIB
handling)
converted to automake.
that contains:
regarded as bugs).
now works).
* removes libbsp/bare/wrapup
* Further cleanups
to make the BSP boot on netboot.
BSP alias on the tools.
because of the conversion to automake and replaced by a Makefile.am.
that converts the libbsp/i386 subdirectory to full automake.
that fixes the following problems:
1. Removing bogus ';' in some configure.in (cosmetical fix)
2. Moves GAS_CODE16 checks to libbsp/i386/*/configure.in (essential fix)
#2 was responsible for the gcc/binutils-2.9.5 choking while building for
the pc386.
registers.
