Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
When it's a macro, a function declaration causes a compiler error due to the
macro being expanded.
Partial log showing error:
https://gist.github.com/AmaanC/ab3521141479aa6f61ea25f5d74ebb4d
Closes #3331
With HAS_SMP set, we have:
libbsp_a_LIBADD += appstart.$(OBJEXT)
When trying to build appstart.o, however, we link start.o with appcpustart.o
through the linkcmds script, which leaves several symbols unresolved, and
without the "-r" (or -i) flag, this throws undefined reference errors.
This change requires us to re-run the ./bootstrap script to regenerate
Makefile.in, and therefore the Makefile for the particular BSP as well.
Complete log of errors available here:
https://gist.github.com/AmaanC/d40bd7393dca1f82965938275845b7f9
Updates #3331
* bsps/shared/cache
Update #3285.
line option.
may suppress warnings.
erc32, imx, qoriq, etc.
* cpukit/include
* cpukit/libnetworking
* bsps/include
* bsps/@RTEMS_CPU@/include
order.
Update #3254.
This header is used also by the motorola_powerpc BSP.
Update #3254.
Update #3254.
The name suggests that this is a private implementation header file.
Update #3254.
Update #3254.
EXTRA_DIST += foobar
in fragments.
Update #3254.
Update #3254.
If this has any issues, check that the change in linking the
16-bit startup code in Makefile.am generates the same code.
This was odd code and didn't need the RTEMS linkcmds anyway.
Updates #3520.
Updates #3520.
Patch was not intended to be pushed yet.
Updates #3520.
Done:
arm
bfin
epiphany
i386
lm32
m32c
mips
moxie
nios2
or1k
powerpc
riscv
sh
sparc
sparc64
v850
To do:
m68k
Differences noted:
+ endfile was sometimes before startfile
+ endfile sometimes was hard-coded and did not have -qrtems version
+ Should -e XXX (e.g. entry point) be in linkcmds?
+ Should -u XXX (e.g. undefined symbols) be in linkcmds?
+ Typos: Odd spacing, "old_endfiles" typo, and *(old_endfiles) (not %)
+ nios2: Referenced crtnn.o not crtn.o (error)
Need to revisit:
+ m32c, moxie, sparc64 includes !nostdlib which is not used elsewhere
+ sh has -EL/-EB mapping. Why needed?
+ sparc64 didn't include crti.o/crtn.o but it is part of toolset
+ v850 uses something like this for link and end_file:
"%{qrtems: %(old_link)}"
This means that these are unnecessary. Try this on all.
+ mips uses old_link all the time also.
+ arm/tms750 adds -EB.
+ powerpc: Why do we have rtems_crt* and not use something from GCC?
Updates #3520.
Updates #3250.
maintain.
Update #3254.
BSP_PRESS_KEY_FOR_RESET=0
BSP_RESET_BOARD_AT_EXIT=1
BSP_PRINT_EXCEPTION_CONTEXT=1
Update #3239.
The removal of the Edison code removed the wrong part of the
conditional.
Closes #3172.
Remove old ISR parameter since is not used by the clock driver shell.
Make an implementation optional.
Update #3139.
The BSP_output_char should output a char and not mingle with high level
processing, e.g. '\n' to '\r\n' translation. Move this translation to
rtems_putc(). Remove it from all the BSP_output_char implementations.
Close #3122.
Update #2132.
Intel has obsoleted this hardware and the BSP was never completed.
closes #3086.
Change bsp_interrupt_vector_enable() and bsp_interrupt_vector_disable()
to not return a status code. Add bsp_interrupt_assert() and use it to
validate the vector number in the vector enable/disable implementations.
Update #2468.
Adding modified FreeBSD headers to synchronize RTEMS termios with
FreeBSD. Modify termios to support dedicated input and output baud for
termios structure. Updated BSPs to use dedicated input and output baud
in termios structure. Updated tools to use dedicated input and output
baud in termios structure. Updated termios testsuites to use dedicated
input and output baud in termios structure.
Close #2897.
When GCC option -march is not specifies i386-rtems toolchain
defaults to i386 architecture instruction set. It does not
provide atomic instructions which results in really inefficient
atomic_fetch_or even on UP build.
SMP build is broken with i386 set because libatomic and GCC
generate infinite loop for __atomic_fetch_add_4 used
in rtems_interrupt_lock_acquire
__atomic_fetch_add_4:
push %ebp
mov %esp,%ebp
movl $0x5,0x10(%ebp)
pop %ebp
jmp __atomic_fetch_add_4
The global state of enabled and disabled interrupts has to hold
interrupts really disabled by drivers and system. If the state is
combined with interrupts temporarily disabled because they are
processed at given time then it is impossible to maintain state
by interrupt handlers in drivers.
more available on i386.
This change is required to build RTEMS with classic "--enable-networking"
and link applications/tests which reference RTEMS_BSP_NETWORK_DRIVER_ATTACH.
