* network_ada/adasockets/AUTHORS,
network_ada/adasockets/sockets-link.ads,
network_ada/adasockets/sockets-multicast.adb,
network_ada/adasockets/sockets-multicast.ads,
network_ada/adasockets/sockets-utils.adb,
network_ada/adasockets/sockets-utils.ads,
network_ada/adasockets/sockets.adb,
network_ada/adasockets/sockets.ads,
network_ada/listener/listener.adb,
network_ada/tcprelay/tcprelay.adb: Convert to utf-8.
* console/fb_vga.c, console/kd.h: Convert C++ style comments to C
style.
memory autodetection code can easily fail (boards with
'reserved' regions - I experienced a hard lockup on a
dell precision 490 when writing past the bios-reported
memory size) I added code that a) tries to save
and use multiboot info, if present b) allows applications
to override/set memory size via a weak alias.
-1 on failure, not just non-zero status. I found that
some driver(s) [e.g. dec21140] explicitely check for -1.
* configure.ac, console/console.c: Add USE_COM1_AS_CONSOLE BSP option.
This makes it easy to build the pc386 BSP in a configuration that
corresponds to qemu with COM1 redirected to stdio.
* configure.ac: Remove explicit ampolish3 support (now in
RTEMS_BSP_CONFIGURE).
* configure.ac: Add ampolish3 support.
* Makefile.am: Add preinstall.am.
* shared/irq/idt.c: Reflect API changes.
* timer/timer.c: Remove C++-style comments.
* shared/pci/pcibios.c: replaced pci_find_device implementation by a
pcibios call which already provides the functionality
* startup/ldsegs.S: put IDT and GDT into data segment. The CPU modifies
the 'accessed' bit and GDB's (rtems-gdb-stub) text segment checksum
comparison failed...
* Makefile.am: Add pci.rel.
* console/fb_vga.h, console/kd.h, console/ps2_drv.h,
console/serial_mouse.c, console/serial_mouse.h: Remove CVS Log.
* shared/comm/i386_io.h, shared/comm/tty_drv.c,
shared/comm/tty_drv.h: Remove CVS Log.
* Makefile.am: Install/preinstall headers from ../../i386/shared.
* Makefile.am: Merge-in shared/Makefile.am.
* ChangeLog: Merge-in shared/ChangeLog.
* configure.ac: Remove shared/Makefile.am.
PR 649/bsps
* ide/idecfg.c, configure.ac:
added configuration items for primary/secondary IDE interface
* network/ne2000.c: Include <errno.h> instead of <sys/errno.h>.
* 3c509/3c509.c: Remove [$]Log.
* network/network.c: Remove #define KERNEL.
Include <errno.h>.
* Makefile.am: Add -D_KERNEL to network_CPPFLAGS.
* timer/timer.c: Enhance to use either interupt-based timer
functions on older CPUs or to use TSC-based timer functions on
more recent (Pentium and above) CPUs. The decision is made in
Timer_initialize function when it is called for the first time
based on a result obtained from cpuid instruction during the BSP
initialization phase. During the first call, there are also late
bindings to the implementation functions initialized to
appropriate values.
* startup/bspstart.c: Initialize PCI bus in bsp_start function.
PR 813/networking
* ne2000/ne2000.c: The ne2000 driver on pc386 has been broken since a
parameter was added to irq handlers (2005-04-18). Before these
changes the argument to the interrupt handler was the interrupt
number, now the argument is handle, but the ne2000 driver needs the
interrupt number. The fix is to set the handle to the interrupt
number.
* console/keyboard.c: Apply CHAR_BIT to compute BITS_PER_LONG.
* include/bsp.h: New header guard.
