* startup/linkcmds: Add FreeBSD SYSCTL() sections for networking.
* ChangeLog: Fix ChangeLog-entry.
* 3c509/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* ne2000/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* wd8003/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* console/console.c: Removed __assert() which conflicts with newlib.
* bin2boot.c: #include POSIX compliant <string.h> instead of BSD
proprietary memory.h.
* configure.ac: Remove duplicate
AC_CONFIG_FILES(ts_1325_ada/Makefile).
* configure.ac: Remove RTEMS_OUTPUT_BUILD_SUBDIRS.
* network/network.c: Removed warnings.
* console/console.c, network/network.c: Removed warnings.
* console/console.c, network/ne2000.c: Removed warnings.
* startup/bspstart.c: Removed warnings.
* comm/i386-stub.c: Fixed places where debug_error() was not called
with enough arguments.
* comm/i386-stub.c: Removed warnings.
* .cvsignore: Reformat.
Add autom4te*cache.
Remove autom4te.cache.
* start/start16.S: Remove unwanted + at beginning of relative
numeric label.
numeric label.
* configure.ac: Remove duplicate timer/Makefile in AC_CONFIG_FILES.
* pci/pcibios.c: #include <string.h>.
* console/Makefile.am: Add $(PROJECT_INCLUDE)/rtems to
PREINSTALL_FILES.
* console/mouse_parser.c: Include <string.h> (for strcmp).
* console/vt.c: Include <string.h> (for memcpy).
* wd8003/wd8003.c: Include <string.h> (for memcpy, memset).
* start/start16.S: Per PR259, added code to test for video present
before touching the adapter. Eric Norum <eric.norum@usask.ca>
tested this patch.
* console/ps2_mouse.c: Include <string.h> (for abort/exit).
* network/Makefile.am: Use .$(OBJEXT) instead of .o.
* 3c509/Makefile.am: Use .$(OBJEXT) instead of .o.
* ne2000/Makefile.am: Use .$(OBJEXT) instead of .o.
* wd8003/Makefile.am: Use .$(OBJEXT) instead of .o.
* pci/pcibios.c: Per PR262, removed all asserts so probes for
devices that are not present will work. This lets you have
multiple PCI Ethernet drivers in an application and dynamically
use the one for the card othat is present.
* startup/ldsegs.S: #include <asm.h>.
* include/bsp.h: Remove _IBMPC_chrdy (is not a public function).
Remove printk (Now in bspIo.h).
* Makefile.am: Add transform and bsptools_bindir hacks.
* startup/bspstart.c: Per PR252 removed hack that tripled size of
RTEMS Workspace when POSIX is configured. This was probably done to
account for confdefs.h missing some application requirements.
Add bsplib_DATA += $(PROJECT_RELEASE)/lib/start16$(LIB_VARIANT).bin.
* console/console.c: Others on the rtems-users list have expressed
concern about this run-time selection, so I've enclosed the changes
in a #ifdef RTEMS_RUNTIME_CONSOLE_SELECT conditional.
* comm/uart.c: I am using a PC-104 card with no video output. I
found that things would lock up if a printk was followed closely by
a printf when BSPConsolePort = BSP_UART_COM2 and
BSPPrintkPort = BSP_UART_COM1. With this change in place,
printf/printk calls can be intermingled with no apparent problems.
* startup/linkcmds: Per PR224, added wild card math to .rodata.
* console/console.c, fatal/bspfatal.c, startup/bspclean.c,
startup/page_table.c: Per PR200 fix multi-line inline assembly
to satisfy gcc 3.1 and newer.
* startup/linkcmds: In support of gcc 3.1, added one of more
of the sections .jcr, .rodata*, .data.*, .gnu.linkonce.s2.*,
.gnu.linkonce.sb2.*, and .gnu.linkonce.s.*. Spacing corrections
and direction of segments to memory regions may also have been
addressed. This was a sweep across all BSPs.
* configure.ac: Remove AC_EXEEXT (obsolete).
* include/bsp.h: include <libcpu/cpu.h>.
* console/console.c: Remove unused variable console_open_count.
