+ libbsp/sparc/shared/include/pci.h was largely a copy of
an older version of the cpukit pci.h. Removed much of the
contents and included <rtems/pci.h>.
+ sparc/*/pci*.c - Move to <rtems/pci.h> required updating
to use uint32_t for dword accesses.
+ Rename PCI_MULTI_FUNCTION to PCI_HEADER_TYPE_MULTI_FUNCTION
+ Define PCI_HEADER_TYPE_MULTI_FUNCTION in cpukit pci.h and remove
PCI_MULTI_FUNCTION definitions in C files.
+ Move PCI_INVALID_VENDORDEVICEID definitions from various C files
to cpukit pci.h
These modifications were required by hand after running the script.
In some cases, the file names did not match patterns. In others,
the format of the file did not match any common patterns.
The clock drivers were very inconsistent about prototyping
the ISR handlers. This broke with the recent clean up.
Tested on qemu.
- RTD316 is a PC-104 board with one Z85C30 SCC for two synchronous
or asynchronous serial ports.
http://www.rtd.com/PC104/UM/network/CM316HR.htm
- Exar 17D15X is a chip with 2, 4, or 8 NS16550 compatible
serial ports with a PCI interface. It may be found on
many multi-port serial ports including:
http://www.rtd.com/PC104/UM/network/CM17320HR.htm
This was broken by conversion of console driver to libchip style.
* console/vt.c: Make _kd_mksound static.
* ide/ide.c: Make pc386_ide_probe, pc386_ide_initialize,
pc386_ide_read_reg, pc386_ide_write_reg, pc386_ide_write_block,
pc386_ide_control, pc386_ide_config_io_speed static.
* shared/pci/pcibios.c: Make pcib_find_by_devid static.
* console/vgacons.c: Add VGACONS_STATIC.
* console/vgacons.h: Remove VGACONS_STATIC.
PR 1925
* shared/irq/irq.h: Changed i386 console to libchip style console and
added support for com3 and com4.
PR 1925
* Makefile.am, preinstall.am, console/serial_mouse_config.c,
include/bsp.h, start/start.S: Converted 1386 console to the libchip
style console
* console/conscfg.c, console/console_control.c,
console/printk_support.c, console/vgacons.c, console/vgacons.h: New
files.
* shared/comm/uart.c (uartError): Remove unused var "uartStatus".
* ne2000/ne2000.c: Remove unused var "stat".
* shared/comm/uart.c: Remove unused var "tmp".
* configure.ac: Formatting. Remove duplication BSP_HAS_SMP.
* shared/irq/irq_asm.S: BUGFIX (introduced by SMP changes
which moved code around, apparently): *must* store i8259
mask to frame *before* switching to IRQ stack. The code
retrieves the mask after switching back to original stack.
Also, the IRQ stack has no reserved space for the mask;
storing it there could overwrite memory!
PR 1802
* shared/irq/irq_asm.S, shared/irq/irq_init.c, shared/smp/smp-imps.c,
shared/smp/smp-imps.h: Add SMP support for i386.
* shared/smp/getcpuid.c: New file.
PR 1802
* Makefile.am, configure.ac, preinstall.am, clock/ckinit.c,
start/start16.S, startup/bspstart.c, startup/ldsegs.S: Add SMP
support for i386.
* start/start16.S: Removed tabs and added OAR standard copyright header
in preperation for merging SMP support.
* shared/irq/apic.h, shared/smp/smp-imps.c, shared/smp/smp-imps.h:
Reformat to be more compliant with RTEMS style.
* shared/irq/apic.h, shared/smp/smp-imps.c, shared/smp/smp-imps.h: Per
email with Erich Boleyn, change license to BSD style.
* shared/irq/irq.c, shared/irq/irq.h, shared/irq/irq_init.c: Add
initial support for APIC.
* shared/irq/apic.h, shared/smp/README, shared/smp/smp-imps.c,
shared/smp/smp-imps.h: New files.
* start/start.S: Moved enable_sse into a subroutine that may be called
from other cores on an SMP system.
PR 1833/bsps
* ne2000/ne2000.c: Addition of multicast support disabled broadcast
reception. Patch also includes support to work on big endian CPUs.
* make/custom/pcp4.cfg: New file.
* Makefile.am: Fix broken path to clockdrv_shell.h.
PR 1792/bsps
* src/lib/libbsp/i386/pc386/Makefile.am,
src/lib/libbsp/sparc/erc32/Makefile.am,
src/lib/libbsp/sparc/leon2/Makefile.am,
src/lib/libbsp/sparc/leon3/Makefile.am: Added a generic smp wait
method to sparc and i386 bsps.
* src/lib/libbsp/shared/smp/bspsmp_wait_for.c: New file.
* shared/comm/tty_drv.c, shared/comm/tty_drv.h:
Remove CVS-Headers. Add CVS-Ids.
* shared/irq/irq_asm.S: Rename rtems_smp_maximum_processors to
rtems_configuration_smp_maximum_processors since it is defined in
confdefs.h.
* ne2000/ne2000.c: Add multicast support. Patch submitted to mailing
list 2005-12-21.
PR 1768/bsps
* shared/irq/irq_asm.S: The nbench benchmark highlighted the fact that
we do not perform a cld before calling C code in the ISR. This was
historically not a problem but gcc 4.3 changed the behavior. From
http://gcc.gnu.org/gcc-4.3/changes.html
PR 1729/cpukit
* Makefile.am, configure.ac: Add next step in SMP support. This adds an
allocated array of the Per_CPU structures to support multiple cpus vs
a single instance of the structure which is still used if SMP support
is disabled. Configuration support is also added to explicitly enable
or disable SMP. But SMP can only be enabled for the CPUs which will
support it initially -- SPARC and i386. With the stub BSP support, a
BSP can be run as a single core SMP system from an RTEMS data
structure standpoint.
PR 1729/cpukit
* shared/irq/irq_asm.S: Add next step in SMP support. This adds an
PR 1762/cpukit
* Makefile.am, preinstall.am, console/console.c, console/keyboard.c,
console/keyboard.h, console/pc_keyb.c, console/ps2_mouse.c,
console/vgainit.c: Made mouse parser engine generic. Now use generic
serial mouse driver. Moved many externs from C to .h.
* console/kbd_parser.c, console/serial_mouse_config.c: New files.
* console/mouse_parser.c, console/mouse_parser.h,
console/serial_mouse.c, console/serial_mouse.h: Removed.
* timer/timer.c: Retry up to 5 times when the calibration loop fails.
