* | Remove eof include file | Ralf Corsepius | 2006-03-17 | 12 | -12/+0 |
* | 2006-02-01 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2006-02-01 | 3 | -1/+17 |
| | | | | | | * configure.ac, console/console.c: Add USE_COM1_AS_CONSOLE BSP option. This makes it easy to build the pc386 BSP in a configuration that corresponds to qemu with COM1 redirected to stdio. | ||||
* | Regenerate. | Ralf Corsepius | 2006-01-14 | 3 | -3/+3 |
* | Regenerate. | Ralf Corsepius | 2006-01-12 | 3 | -0/+12 |
* | Remove all-local:. | Ralf Corsepius | 2006-01-12 | 3 | -6/+0 |
* | Regenerate. | Ralf Corsepius | 2006-01-12 | 2 | -2/+2 |
* | Cleanup. | Ralf Corsepius | 2006-01-12 | 3 | -7/+0 |
* | 2006-01-11 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-01-11 | 6 | -12/+15 |
| | | | | | * configure.ac: Remove explicit ampolish3 support (now in RTEMS_BSP_CONFIGURE). | ||||
* | 2006-01-10 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-01-10 | 9 | -246/+33 |
| | | | | | * configure.ac: Add ampolish3 support. * Makefile.am: Add preinstall.am. | ||||
* | New. | Ralf Corsepius | 2006-01-10 | 3 | -0/+272 |
* | Fixed formatting. | Joel Sherrill | 2005-11-07 | 1 | -1/+1 |
* | 2005-11-06 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-11-06 | 1 | -0/+4 |
| | | | | * shared/irq/idt.c: Reflect API changes. | ||||
* | Reflect API changes. | Ralf Corsepius | 2005-11-06 | 1 | -3/+3 |
* | 2005-11-06 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-11-06 | 1 | -3/+8 |
| | | | | * timer/timer.c: Remove C++-style comments. | ||||
* | Remove C++-style comments. | Ralf Corsepius | 2005-11-06 | 1 | -2/+2 |
* | Added reference to PR#832 | Till Straumann | 2005-11-04 | 1 | -2/+2 |
* | corrected redundant PR number | Till Straumann | 2005-11-04 | 1 | -1/+1 |
* | Added reference to PR#838 | Till Straumann | 2005-11-04 | 1 | -4/+4 |
* | 2005-11-02 straumanatslacdotstanford.edu | Till Straumann | 2005-11-03 | 2 | -49/+16 |
| | | | | | * shared/pci/pcibios.c: replaced pci_find_device implementation by a pcibios call which already provides the functionality | ||||
* | 2005-11-02 straumanatslacdotstanford.edu | Till Straumann | 2005-11-03 | 2 | -6/+11 |
| | | | | | | * startup/ldsegs.S: put IDT and GDT into data segment. The CPU modifies the 'accessed' bit and GDB's (rtems-gdb-stub) text segment checksum comparison failed... | ||||
* | Add pci.rel to librtemsbsp.a | Ralf Corsepius | 2005-10-17 | 2 | -2/+2 |
* | Cosmetics. | Ralf Corsepius | 2005-10-17 | 1 | -1/+1 |
* | 2005-10-17 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-10-17 | 4 | -0/+30 |
| | | | | * Makefile.am: Add pci.rel. | ||||
* | 2005-10-17 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-10-17 | 1 | -0/+5 |
| | | | | | * console/fb_vga.h, console/kd.h, console/ps2_drv.h, console/serial_mouse.c, console/serial_mouse.h: Remove CVS Log. | ||||
* | Remove CVS Log | Ralf Corsepius | 2005-10-17 | 8 | -294/+0 |
| | | | | | * shared/comm/i386_io.h, shared/comm/tty_drv.c, shared/comm/tty_drv.h: Remove CVS Log. | ||||
* | 2005-10-17 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-10-17 | 6 | -17/+105 |
| | | | | * Makefile.am: Install/preinstall headers from ../../i386/shared. | ||||
* | 2005-10-16 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-10-17 | 3 | -24/+256 |
| | | | | | | * Makefile.am: Merge-in shared/Makefile.am. * ChangeLog: Merge-in shared/ChangeLog. * configure.ac: Remove shared/Makefile.am. | ||||
* | Remove. | Ralf Corsepius | 2005-10-17 | 3 | -306/+0 |
* | Added PR number. | Joel Sherrill | 2005-09-29 | 1 | -1/+1 |
* | 2005-09-29 Thomas Doerfler <Thomas.Doerfler@imd-systems.de> | Thomas Doerfler | 2005-09-29 | 3 | -1/+41 |
| | | | | | | PR 649/bsps * ide/idecfg.c, configure.ac: added configuration items for primary/secondary IDE interface | ||||
* | Correct my email address. | Ralf Corsepius | 2005-09-19 | 1 | -8/+8 |
* | Include <errno.h> instead of <sys/errno.h>. | Ralf Corsepius | 2005-09-19 | 1 | -1/+1 |
* | 2005-09-19 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-09-19 | 1 | -0/+4 |
| | | | | * network/ne2000.c: Include <errno.h> instead of <sys/errno.h>. | ||||
* | 2005-09-19 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-09-19 | 2 | -40/+8 |
| | | | | | * 3c509/3c509.c: Remove [$]Log. Include <errno.h> instead of <sys/errno.h>. | ||||
* | 2005-09-19 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-09-19 | 3 | -3/+8 |
| | | | | | | * network/network.c: Remove #define KERNEL. Include <errno.h>. * Makefile.am: Add -D_KERNEL to network_CPPFLAGS. | ||||
* | 2005-08-23 Karel Gardas <kgardas@objectsecurity.com>> | Joel Sherrill | 2005-08-31 | 2 | -13/+73 |
| | | | | | | | | | | | * timer/timer.c: Enhance to use either interupt-based timer functions on older CPUs or to use TSC-based timer functions on more recent (Pentium and above) CPUs. The decision is made in Timer_initialize function when it is called for the first time based on a result obtained from cpuid instruction during the BSP initialization phase. During the first call, there are also late bindings to the implementation functions initialized to appropriate values. | ||||
* | Remove duplicate comment. | Joel Sherrill | 2005-08-22 | 1 | -4/+0 |
* | 2005-08-18 Karel Gardas <kgardas@objectsecurity.com> | Joel Sherrill | 2005-08-18 | 2 | -0/+19 |
| | | | | * startup/bspstart.c: Initialize PCI bus in bsp_start function. | ||||
* | 2005-07-18 Lars Munch <lars@segv.dk> | Joel Sherrill | 2005-07-18 | 2 | -0/+11 |
| | | | | | | | | | | PR 813/networking * ne2000/ne2000.c: The ne2000 driver on pc386 has been broken since a parameter was added to irq handlers (2005-04-18). Before these changes the argument to the interrupt handler was the interrupt number, now the argument is handle, but the ne2000 driver needs the interrupt number. The fix is to set the handle to the interrupt number. | ||||
* | 2005-07-06 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-07-06 | 2 | -1/+6 |
| | | | | * console/keyboard.c: Apply CHAR_BIT to compute BITS_PER_LONG. | ||||
* | 2005-05-26 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-05-26 | 6 | -7/+19 |
| | | | | * include/bsp.h: New header guard. | ||||
* | 2005-05-23 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2005-05-23 | 2 | -1/+6 |
| | | | | | * comm/i386-stub.c: Make get_char() static since it is such a common name and conflicts with names in the standard Ada run-time. | ||||
* | 2005-05-17 Jennifer Averett <jennifer.averett@oarcorp.com> | Jennifer Averett | 2005-05-17 | 2 | -178/+20 |
| | | | | * irq/irq.c, irq/irq.h: Modified to include rtems/irq.h. | ||||
* | 2005-05-10 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-05-10 | 2 | -1/+5 |
| | | | | * pci/pcibios.c: Eliminate unsigned8. | ||||
* | 2005-05-06 Jennifer Averett <jennifer.averett@oarcorp.com> | Jennifer Averett | 2005-05-06 | 5 | -4/+9 |
| | | | | | * clock/ckinit.c, console/console.c, include/bsp.h, network/ne2000.c: Moved irq.h to bsp subdirectory. | ||||
* | 2005-05-06 Jennifer Averett <jennifer.averett@oarcorp.com> | Jennifer Averett | 2005-05-06 | 10 | -15/+33 |
| | | | | | | * Makefile.am, comm/i386-stub-glue.c, comm/tty_drv.c, comm/uart.c, irq/idt.c, irq/irq.c, irq/irq.h, irq/irq_asm.S, irq/irq_init.c: Moved irq.h and irq_asm.h to bsp subdirectory. | ||||
* | 2005-05-06 Jennifer Averett <jennifer.averett@oarcorp.com> | Jennifer Averett | 2005-05-06 | 11 | -10/+34 |
| | | | | | | | * 3c509/3c509.c, clock/ckinit.c, console/console.c, console/fb_vga.c, console/inch.c, console/ps2_mouse.c, console/serial_mouse.c, ne2000/ne2000.c, timer/timer.c, wd8003/wd8003.c: Moved irq.h to bsp subdirectory. | ||||
| | | | | | * clock/ckinit.c, console/console.c, include/bsp.h, startup/bspstart.c: Moved irq.h to bsp subdirectory. | ||||
* | 2005-05-04 Jennifer Averett <jennifer.averett@oarcorp.com> | Jennifer Averett | 2005-05-04 | 3 | -221/+300 |
| | | | | | | * pci/pcibios.c, pci/pcibios.h: Corrected spacing Name modifications for a generic PCI interface Added wrapper routines for pci read/write configuration data |
