returned an error to using a single shared copy of this file.
be resolved.
djgpp v1.x.
added standard comments about driver entries.
only required in a multiprocessor system. It was replace by the MPCI
Receive Server. As a result, the CPU Table field for extra stack for
the SYSI task was changed to be extra stack for the MPCI Receive Server.
a pre-release snapshot for 3.5.1
like signal dispatching.
IDLE task priority changed from 0 to 255 during initialization.
