to added the bin2boot_SOURCES warning.
delay loop in this BSP. Here is his response to a question about
the patch:
Yes, or that other machine has a different chipset with different
timing requirements on enabling Gate 20. I am strongly suspecting
that it may some how related to the video card I am using (on my
old P-75 target it was plain PCI VGA, on my new one it is Diamond Stealth
3D 2000).
dec21140 drivers from the i386/pc386 and powerpc/mcp750 (all Motorola
PowerPC boards) and move the network driver to libchip. This driver
should work on all PCI based uses of this chip.
to consistently use $(EXEEXT).
*.cfg files.
dependencies
automake and RTEMS make rules
convention)
performs automatically.
WARNING:
Makefile.ams.
increase ease of application configuration of the pc386 BSP. This
patch allows switching the printk console to a serial port and
overriding bsp_start by making it a weak alias.
the receive buffer size was 16 bytes too small.
proper Multiboot signature to pc386 BSP. This enables Grub to
recognize the image.
reported bugs in the start code.
conditional that should have been fixed long ago.
and not likely to become so. Comments on each configuration
are below.
+ Force CPU386 - This BSP was developed as part of the initial
port of RTEMS to the i386. This board has been unavailable
for a long time now.
+ GO32 - This BSP and some CPU code supported djgpp v1.x. This
version is now quite old. No one has stepped forward to
update the code to v2.x which may be technically impossible
anyway. More importantly, go32 has been superceded by the pc386 BSP.
mkdir c/src/librpc
mkdir c/src/librpc/src
mkdir c/src/librpc/include
rm -rf c/src/lib/librpc
rm -rf c/src/lib/include/rpc
in the required order .
# make[5]: Entering directory
# mips64orion-rtems-gcc -v
# mips64orion-rtems-ld -v
I'm attaching a big patch for the ts_386ex BSP which adds and includes
the following:
1) Conversion to ELF format + minor code cleanups + documentation.
2) An Ada95 binding to FreeBSD sockets, based on Samuel Tardieu's
adasockets-0.1.3 package. This includes some sample applications.
3) Some Ada and C interfaces to add serial-port debugging to
programs. Comes with examples, too; the Ada one shows how
transparent adding the support can be. Note that Rosimildo sent me
the original C code.
The network stuff is not BSP specific, and could be added to your Ada
code collection. The debugging stuff is specific to the i386. Right
now, everything sits in my "tools" directory.
initialization typo and make i8259s_cache only accessed from C.
to fix problem reported by Ralf Corsepius <corsepiu@faw.uni-ulm.de>.
Date: Fri, 30 Jul 1999 14:53:20 -0500 (CDT)
it is used like this in i386ex/start/start.S
/* set up same values in cache */
start.S: movw $0xFFFB, SYM(i8259s_cache)
I am heading out the door. Any other ideas what could have tripped this?
This instruction appears in a .code16 section. In a .code16 section,
current versions of gas assume that all addresses are 16 bits unless
told otherwise.
If you change the line to
addr32 movw $0xFFFB, SYM(i8259s_cache)
then you will get a 32 bit address reference.
You may want to use addr32 only when NEW_GAS is defined.
CHANGES
autoconf check
autoconf check
$(prefix)/<bsp>/make/bsp.cfg
compatible.
Makefile.ins
bug report from David Decotigny <David.Decotigny@irisa.fr>:
During the last few days, I've been back working on RTEMS. Let me
remind you that RTEMS didn't boot on our (old) Dell P90 machines (ref:
PC 590) : we could only get a reboot out of them.
1/ The symptoms
Hopefully, the problem was rather deterministic. The stack couldn't be
written correctly : issueing one or more "push" would always push '0'
onto the stack. The way to solve this was to issue a "pop", such as
"pushl eax ; popl eax". After this "pop", the stack would be writeable
again.
BUT, it will be writable for 8 consecutive "push"s. After these 8
"push"s, the other "push"s are wrong again, and a blank push/pop is
needed.
Considering that the L1 cache lines of this pentium are 32 bytes long,
and that 8 long int are 32 bytes long too, it came to us that there
was a problem with the cache.
Actually, the bug of the push could be shown through memory accesses
directly : writing on an not-in-cache mem location would put 0 until
this mem location is accessed through a single "read". Then, the whole
cache line would be right again.
2/ The consequences
Of course, that was the first thing that we've been able to observe ;)
RTEMS could not boot. Actually, when a "call" pushed 0 onto the stack,
the ret could only lead to raise an exception a bit later. Since, in
the early stage, the Interrupt vector points to 0, averything couldn't
get worse : triple fault + reboot.
3/ Explanation
This cache mechanism corruption only appeared after load_segment()
returned (through a jump). Investigating a bit further shows that this
appears /sometimes/ during the PICs initialization.
"Sometimes" proved to be "When writing something with the 4th bit of
%al set". That is "when writing 0x28 or 0xff" for example. Clearing
this bit would just make the things work right.
Actually, this isn't a bug in the proper PIC initialization (which is
quite academic). It came from the "delay" routine, which theoretically
does nothing but writing to an "inexistant" port (0xed), in order to
lose some time.
BUT, in the special case of our Dell P90, it appears that this 0xed
port does something cruel with the cache mechanism when its 4th bit
(aka bit 3 or 0x8) is set.
I didn't investigate this non-standard behaviour of the P90 any
further : I don't know if this is documented, or if it is just another
(known ?) bug of the early Pentiums. Just notice that we have 5 such
machines, and it has the same effect on the cache mechanism.
CHANGES:
c/Makefile.am removed
still in - remove it?)
(Cygwin support)
REMARK:
inside the build-tree.
APPLYING THE PATCH
autogen
dependencies of "Makefile".
--enable-maintainer-mode.
ncurses, and zlib for RTEMS.
link even if they do not actually support Ada interrupts.
David.Decotigny@irisa.fr and discussion with Joel. Basically interrupts
were enabled too early in this BSP.
> When I run my script that just repeatedly builds different targets, some
> of them die with an error like this:
> Making all RTEMS_BSP=gen68360 in cpugmake[5]: Entering directory
> `/usr1/rtems/build/build-m68k-rtems/c/src/exec/score/cpu'
> Making all RTEMS_BSP=gen68360 in @RTEMS_CPU@
> /bin/sh: @RTEMS_CPU@: No such file or directory
> gmake[5]: *** [all] Error 1
> gmake[5]: Leaving directory
> It is not always the same variable substitution that fails. Sometimes it
> is @INSTALL@. But reliably, it is a variable substitution that is
> failing.
> Do you have any idea why this happens?
Yep, I think I know what's going on.
AC_SUBST(RTEMS_CPU) is missing in configure.ins, thus @RTEMS_CPU@ in
target.cfg.in doesn't get substituted correctly, causing the bug above. Due
to the redundancy of RTEMS_CPU, other most BSPs don't seem to be affected.
Other similar problems probably exist for the unix/posix bsp and the hppa.1
cpu, because their */tools/*Makefile.ams require RTEMS_CPU, too.
exceptions work on the pc386 BSP with i386-elf. This patch also
included changes to the i386-rtemself egcs configuration.
