* bsp_specs: Remove *lib:.
* clock/ckinit.c, clock/rtc.c, console/console.c, include/bsp.h,
include/coverhd.h, network/ne2000.c, start/80386ex.h,
start/80386ex.inc, start/macros.inc, start/start.S,
startup/bspstart.c, startup/linkcmds, startup/setvec.c,
timer/timer.c, timer/timerisr.S, tools/debug_ada/init.c,
tools/debug_c/init.c, tools/debug_c/serial_gdb.c,
tools/debug_c/system.h, tools/network_ada/listener/init.c,
tools/network_ada/tcprelay/init.c, tools/ts_1325_ada/init.c: URL for
license changed.
* comm/gdb_glue.c, irq/idt.c, irq/irq.c, irq/irq.h, irq/irq_asm.S,
irq/irq_asm.h, irq/irq_init.c: URL for license changed.
* clock/ckinit.c, clock/rtc.c, console/console.c, console/inch.c,
console/outch.c, ide/ide.c, include/bsp.h, include/crt.h,
ne2000/ne2000.c, start/start.S, startup/bspstart.c, startup/exit.c,
startup/ldsegs.S, startup/linkcmds, timer/timer.c, timer/timerisr.S:
start/80386ex.h, start/80386ex.inc, start/macros.inc, start/start.S,
timer/timer.c, timer/timerisr.S: URL for license changed.
PR 456/bsps
* irq/irq.c: Fix race condition when installing an ISR.
PR 461/bsps
* start/Makefile.am: Correct generation of startup16.bin.
* ide/Makefile.am: Don't include @RTEMS_BPS@.cfg.
debug_ada/Makefile.am: Reflect having moved automake.
debug_c/Makefile.am: Reflect having moved automake.
dos_sup/Makefile.am: Reflect having moved automake.
network_ada/Makefile.am: Reflect having moved automake.
network_ada/adasockets/Makefile.am: Reflect having moved automake.
network_ada/listener/Makefile.am: Reflect having moved automake.
network_ada/tcprelay/Makefile.am: Reflect having moved automake.
ts_1325_ada/Makefile.am: Reflect having moved automake.
comm/Makefile.am: Reflect having moved automake.
io/Makefile.am: Reflect having moved automake.
irq/Makefile.am: Reflect having moved automake.
pci/Makefile.am: Reflect having moved automake.
3c509/Makefile.am: Reflect having moved automake.
ide/Makefile.am: Reflect having moved automake.
ne2000/Makefile.am: Reflect having moved automake.
wd8003/Makefile.am: Reflect having moved automake.
PR 451/bsps
* startup/Makefile.am: Include shared i386 TTY driver in these BSPs.
PR 453/make_build
* startup/linkcmds: Added .eh_frame
* startup/Makefile.am: Remove USE_INIT_FINI.
PR 428/bsps
PR 432/bsps
* pci/pcibios.c, pci/pcibios.h: Added BSP_pci_Find_Device() which
is copied from motorola_shared.
* console/console.c: Correct typo.
Added how to boot over the network with a PXE Netboot BIOS.
* ide/.cvsignore: New.
PR 368/filesystems
* startup/ldsegs.S: Increase alignment.
* Makefile.am, configure.ac, include/bsp.h, wrapup/Makefile.am:
Added IDE supporting infrastructure.
* ide/Makefile.am, ide/ide.c, ide/idecfg.c: New files. Added
BSP support for libchip standard ide driver.
* comm/GDB.HOWTO: Updated.
PR 353/bsps
* include/bsp.h: Let the application override the network driver
and attach routine.
* startup/linkcmds: Add FreeBSD SYSCTL() sections for networking.
* ChangeLog: Fix ChangeLog-entry.
* 3c509/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* ne2000/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* wd8003/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* console/console.c: Removed __assert() which conflicts with newlib.
* bin2boot.c: #include POSIX compliant <string.h> instead of BSD
proprietary memory.h.
* configure.ac: Remove duplicate
AC_CONFIG_FILES(ts_1325_ada/Makefile).
* configure.ac: Remove RTEMS_OUTPUT_BUILD_SUBDIRS.
* network/network.c: Removed warnings.
* console/console.c, network/network.c: Removed warnings.
