* Makefile.am: Reflect changes to bsp.am.
* Makefile.am: Use CPPASCOMPILE instead of CCASCOMPILE.
* Makefile.am: Pickup files from ../../i386/shared instead of
../shared. Reformat.
* Makefile.am: Merge-in debug_ada/Makefile.am, debug_c/Makefile.am,
dos_sup/Makefile.am, network_ada/adasockets/Makefile.am,
network_ada/Makefile.am, network_ada/listener/Makefile.am,
network_ada/tcprelay/Makefile.am, ts_1325_ada/Makefile.am. Use automake
compilation rules.
* debug_ada/Makefile.am, debug_c/Makefile.am, dos_sup/Makefile.am,
network_ada/adasockets/Makefile.am, network_ada/Makefile.am,
network_ada/listener/Makefile.am, network_ada/tcprelay/Makefile.am,
ts_1325_ada/Makefile.am: Remove.
network/Makefile.am, startup/Makefile.am, timer/Makefile.am,
wrapup/Makefile.am. Use automake compilation rules.
* clock/Makefile.am, console/Makefile.am, network/Makefile.am,
startup/Makefile.am, timer/Makefile.am, wrapup/Makefile.am: Remove.
* configure.ac: Add nostdinc to AUTOMAKE_OPTIONS.
Add RTEMS_PROG_CCAS.
* wrapup/Makefile.am: Reflect changes to libcpu.
* startup/Makefile.am: Ditto.
* start/Makefile.am: Remove.
* Makefile.am: Merge-in start/Makefile.am.
* wrapup/Makefile.am: Eliminate $(LIB).
Use noinst_DATA to trigger building libbsp.a.
* Makefile.am: Cosmetics.
* debug_ada/Makefile.am: Cosmetics.
* debug_c/Makefile.am: Cosmetics.
* dos_sup/Makefile.am: Cosmetics.
* network_ada/Makefile.am: Cosmetics.
* network_ada/adasockets/Makefile.am: Cosmetics.
* network_ada/listener/Makefile.am: Cosmetics.
* network_ada/tcprelay/Makefile.am: Cosmetics.
* ts_1325_ada/Makefile.am: Cosmetics.
* network/Makefile.am: Cosmetics.
* bsp_specs: Remove *lib:.
* clock/ckinit.c, clock/rtc.c, console/console.c, include/bsp.h,
include/coverhd.h, network/ne2000.c, start/80386ex.h,
start/80386ex.inc, start/macros.inc, start/start.S,
startup/bspstart.c, startup/linkcmds, startup/setvec.c,
timer/timer.c, timer/timerisr.S, tools/debug_ada/init.c,
tools/debug_c/init.c, tools/debug_c/serial_gdb.c,
tools/debug_c/system.h, tools/network_ada/listener/init.c,
tools/network_ada/tcprelay/init.c, tools/ts_1325_ada/init.c: URL for
license changed.
debug_ada/Makefile.am: Reflect having moved automake.
debug_c/Makefile.am: Reflect having moved automake.
dos_sup/Makefile.am: Reflect having moved automake.
network_ada/Makefile.am: Reflect having moved automake.
network_ada/adasockets/Makefile.am: Reflect having moved automake.
network_ada/listener/Makefile.am: Reflect having moved automake.
network_ada/tcprelay/Makefile.am: Reflect having moved automake.
ts_1325_ada/Makefile.am: Reflect having moved automake.
PR 451/bsps
* startup/Makefile.am: Include shared i386 TTY driver in these BSPs.
* startup/Makefile.am: Remove USE_INIT_FINI.
* startup/linkcmds: Add FreeBSD SYSCTL() sections for networking.
* console/console.c: Removed __assert() which conflicts with newlib.
* configure.ac: Remove duplicate
AC_CONFIG_FILES(ts_1325_ada/Makefile).
* console/console.c, network/ne2000.c: Removed warnings.
* startup/bspstart.c: Removed warnings.
* .cvsignore: Reformat.
Add autom4te*cache.
Remove autom4te.cache.
* configure.ac: Remove duplicate timer/Makefile in AC_CONFIG_FILES.
* network/Makefile.am: Use .$(OBJEXT) instead of .o.
