path: root/c/src/lib/libbsp/i386/ts_386ex (follow)
* 2002-03-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-03-2811-11/+17
| | | | | | | | | | | | | | | * configure.ac: AC_INIT(package,_RTEMS_VERSION,_RTEMS_BUGS). AM_INIT_AUTOMAKE([no-define foreign 1.6]). * clock/Makefile.am: Remove AUTOMAKE_OPTIONS. * Makefile.am: Remove AUTOMAKE_OPTIONS. * console/Makefile.am: Remove AUTOMAKE_OPTIONS. * include/Makefile.am: Remove AUTOMAKE_OPTIONS. * network/Makefile.am: Remove AUTOMAKE_OPTIONS. * start/Makefile.am: Remove AUTOMAKE_OPTIONS. * startup/Makefile.am: Remove AUTOMAKE_OPTIONS. * timer/Makefile.am: Remove AUTOMAKE_OPTIONS. * wrapup/Makefile.am: Remove AUTOMAKE_OPTIONS.
| | | | | | | | | | | | | | | * configure.ac: AC_INIT(package,_RTEMS_VERSION,_RTEMS_BUGS). AM_INIT_AUTOMAKE([no-define foreign 1.6]). * debug_ada/Makefile.am: Remove AUTOMAKE_OPTIONS. * Makefile.am: Remove AUTOMAKE_OPTIONS. * debug_c/Makefile.am: Remove AUTOMAKE_OPTIONS. * dos_sup/Makefile.am: Remove AUTOMAKE_OPTIONS. * network_ada/adasockets/Makefile.am: Remove AUTOMAKE_OPTIONS. * network_ada/Makefile.am: Remove AUTOMAKE_OPTIONS. * network_ada/listener/Makefile.am: Remove AUTOMAKE_OPTIONS. * network_ada/tcprelay/Makefile.am: Remove AUTOMAKE_OPTIONS. * ts_1325_ada/Makefile.am: Remove AUTOMAKE_OPTIONS.
* 2002-03-16 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-03-202-1/+5
| | | | * configure.ac: Remove stray ';', PR 139.
* 2002-01-03 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-01-063-2/+6
| | | | * include/bsp.h: Include rtems/bspIo.h instead of bspIo.h.
* 2001-12-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-01-042-1/+6
| | | | | * bsp_specs: Replace -lrtemsall with -lrtemsbsp -lrtemscpu, replace -lrtemsall_g with -lrtemsbsp_g -lrtemscpu_g.
* 2001-11-30 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-12-032-7/+5
| | | | * configure.ac: Introduce RTEMS_BSP_CONFIGURE.
* 2001-11-14 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-11-142-2/+20
| | | | | | * configure.ac: Add RTEMS_BSPOPTS_*(LOAD_RTC_AT_START), RTEMS_BSPOPTS_*(BSP_DEBUG), RTEMS_BSPOPTS_*(UARTDEBUG), remove RTEMS_OUTPUT_BUILD_SUBDIRS.
* 2001-10-12 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-10-122-1/+4
| | | | * startup/linkcmds: Fixed typo.
* 2001-10-12 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-10-125-4/+5
| | | | | * debug_ada/init.c, network_ada/listener/init.c, network_ada/tcprelay/init.c, ts_1325_ada/init.c: Fixed typo.
* 2001-10-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-10-122-0/+79
| | | | | * .cvsignore: Add autom4te.cache for autoconf > 2.52. * configure.in: Remove.
* 2001-10-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-10-122-76/+0
* 2001-10-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-10-114-0/+14
* 2001-09-27 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-09-282-1/+5
| | | | * include/bsp.h: Renamed delay() to rtems_bsp_delay().
* 2001-09-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-09-272-1/+5
| | | | * include/Makefile.am: Use 'PREINSTALL_FILES ='.
* 2001-05-26 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-06-146-4/+18
| | | | | | | * configure.in: Add bspopts.h. * include/.cvsignore: Add bspopts.h*, stamp-h*. * include/Makefile.am: Use *_HEADERS instead of *H_FILES. * include/bsp.h: Include bspopts.h.
* 2001-05-10 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-05-112-1/+5
| | | | * configure.in: Use RTEMS_PROG_CC_FOR_TARGET([-ansi -fasm]).
* 2000-11-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-11-094-2/+10
* 2000-11-02 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-11-024-2/+10
* 2000-11-01 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-11-012-2/+8
| | | | | | | * startup/bspstart.c: assoc.h, error.h, libio_.h, libio.h, and libcsupport.h moved from libc to lib/include/rtems and now must be referenced as <rtems/XXX.h>. Header file order was cleaned up while doing this.
* 2000-10-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-10-275-3/+15
| | | | | * configure.in, Makefile.am: ACLOCAL_AMFLAGS= -I $(RTEMS_TOPdir)/macros. Switch to GNU canonicalization.
* 2000-10-19 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-10-192-1/+6
| | | | | * console/console.c: Invoke BSP_uart_init() with all arguments now that it takes more parameters.
* 2000-10-17 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-10-172-1/+6
| | | | | * startup/Makefile.am: Added idt.c since it has been moved libcpu/i386 to libbsp/i386/shared/irq.
* 2000-09-29 Charles-Antoine Gauthier <charles.gauthier@nrc.ca>Joel Sherrill2000-09-292-0/+47
| | | | | | * startup/linkcmds: Added lines so DWARF debug information would be available. Otherwise gdb complains that the offsets for the debug info are incorrect and doesn't load the files.
* 2000-09-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-09-123-7/+5
| | | | | * start/Makefile.am: Remove AM_CPPFLAGS and GAS_CODE16 conditional. * startup/Makefile.am: Cleanup comments.
* 2000-09-04 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-09-058-1/+14
| | | | | | * clock/Makefile.am, console/Makefile.am, network/Makefile.am, start/Makefile.am, startup/Makefile.am, timer/Makefile.am, wrapup/Makefile.am: Include compile.am
* Adding ChangeLogs.Joel Sherrill2000-08-102-0/+6
* Moved i386 and m68k cache management code to libcpu. EverythingJoel Sherrill2000-06-131-1/+2
| | | | | | now is an implementation of the prototypes in rtems/rtems/cache.h. The libcpu/i386/wrapup directory is no longer needed. The PowerPC needs this done to it.
* Removed references to printk as part of moving it to a more shareableJoel Sherrill2000-06-121-1/+1
| | | | location in libc.
* Merged from 4.5.0-beta3aJoel Sherrill2000-06-1227-124/+63
* Patch rtems-rc-4.5.0-13-cvs.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>.Joel Sherrill2000-04-1318-0/+58
| | | | adds .cvsignore.
* Patches rtems-rc-20000204-0.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-02-082-5/+8
* Patches rtems-rc-20000118-3.diff and rtems-rc-20000118-4.diff fromJoel Sherrill2000-01-318-55/+58
| | | | | | | | | | Ralf Corsepius <corsepiu@faw.uni-ulm.de> that contain: * Modifications, (minor) corrections, cleanups to most existing Makefile.ams * Adds automake support to all remaining BSPs which have not yet been converted to automake. * Makefile.am for all remaining wrapup/Makefile.ams
* Patch rtems-rc-20000104-16.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-01-1225-560/+389
| | | | that converts the libbsp/i386 subdirectory to full automake.
* Patch rtems-rc-20000104-15.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-01-121-0/+4
| | | | | | | | | | that fixes the following problems: 1. Removing bogus ';' in some configure.in (cosmetical fix) 2. Moves GAS_CODE16 checks to libbsp/i386/*/configure.in (essential fix) #2 was responsible for the gcc/binutils-2.9.5 choking while building for the pc386.
* Corrected compilation problem in lgdt instruction.Joel Sherrill2000-01-101-0/+3
* Patch rtems-rc-20000104-11.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-01-1011-47/+76
| | | | | | | | that converts the i386 directory to automake. NOTE: Ralf is unable to build any i386 BSPs. This was true before and after this patch and appears (to Joel) to be a tool issue unrelated since others can build i386 BSPs.
* Patch rtems-rc-19991117-9.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1999-11-225-5/+5
| | | | | to convert the libc directory to automake and "dozens of small fixes for Makefile.ins/configure.ins below c/src/lib."
* Patch rtems-rc-19991117-4.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>:Joel Sherrill1999-11-221-1/+1
* Updated copyright notice.Joel Sherrill1999-11-1712-24/+12
* Removed.Joel Sherrill1999-11-095-298/+0
* Removed aclocal.m4 generated from aclocal macrosJoel Sherrill1999-10-061-266/+0
* Removed configure generated from configure.inJoel Sherrill1999-10-061-1286/+0
* Regenerated.Joel Sherrill1999-10-052-74/+78
* Patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de> to make fix bugJoel Sherrill1999-10-043-9/+9
* Patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de>:Joel Sherrill1999-10-041-1/+1
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | The patch below actuallly consists of two patches: 1) moving librpc to c/src/librpc similar to what has been done to librtems++ 2) reworked configure scripts, many safety and dependency checks added to aclocal/*.m4 macros + configuration fixes. To apply: mkdir c/src/librpc mkdir c/src/librpc/src cp c/src/lib/librpc/*.c c/src/librpc/src cp c/src/lib/librpc/Makefile.in c/src/librpc/src mkdir c/src/librpc/include mkdir c/src/librpc/include/rpc cp c/src/lib/include/rpc/* c/src/librpc/include/rpc patch -p1 < ../rtems-rc-19990820-7.diff rm -rf c/src/lib/librpc rm -rf c/src/lib/include/rpc ./autogen The additional checks in aclocal/*m4 macros add rather restrictive, sometimes unnecessarily restrictive constraints on the sequence of how macros can be used in a configure.in script. Adding them has let my problems with some more complicated configuration options vanish. Apparently some macros had not been in the required order . ---- Now I still get some linking errors for some cpus and bsps, esp when linking cdtest, but also at other locations: e.g. this happens for mips64orion/p4600: # make[5]: Entering directory `/lfs/poseidon/users/rtems/src/multi/build/mips64orion-rtems/c/p4600/tests/samples/hello' /opt/rtems/bin/mips64orion-rtems-gcc --pipe -B../../../../../../p4600/lib/ -specs bsp_specs -qrtems -DP4000 -DCPU_R4000 -DP3_DIAG -D_R4000 -D__mips=3 -mcpu=4600 -G0 -I../../../../../../p4600/lib/include/networking -g -Wall -ansi -fasm -O4 -fomit-frame-pointer -o o-p4600/hello.exe o-p4600/init.o ../../../../../../p4600/lib/no-dpmem.rel ../../../../../../p4600/lib/no-event.rel ../../../../../../p4600/lib/no-msg.rel ../../../../../../p4600/lib/no-mp.rel ../../../../../../p4600/lib/no-part.rel ../../../../../../p4600/lib/no-signal.rel ../../../../../../p4600/lib/no-timer.rel ../../../../../../p4600/lib/no-rtmon.rel /opt/rtems/mips64orion-rtems/lib/libc.a(dtoa.o): In function `_dtoa_r': /opt/hermes/embedded/build/build-mips64orion-tools/mips64orion-rtems/newlib/libc/stdlib/../../../../../src/newlib/libc/stdlib/dtoa.c:348: relocation truncated to fit: R_MIPS_LITERAL no symbol /opt/hermes/embedded/build/build-mips64orion-tools/mips64orion-rtems/newlib/libc/stdlib/../../../../../src/newlib/libc/stdlib/dtoa.c:348: relocation truncated to fit: R_MIPS_LITERAL no symbol /opt/hermes/embedded/build/build-mips64orion-tools/mips64orion-rtems/newlib/libc/stdlib/../../../../../src/newlib/libc/stdlib/dtoa.c:348: relocation truncated to fit: R_MIPS_LITERAL no symbol collect2: ld returned 1 exit status # mips64orion-rtems-gcc -v Reading specs from /opt/rtems/lib/gcc-lib/mips64orion-rtems/2.95.1/specs gcc version 2.95.1 19990816 (release) # mips64orion-rtems-ld -v GNU ld version 2.9.5 (with BFD 2.9.5)
* Removed Makefile.in generated from Makefile.amJoel Sherrill1999-10-043-834/+0
* Regenerated.Joel Sherrill1999-10-045-22/+28
* Applied patch rtems-rc-19990820-6.diff.gz fromJoel Sherrill1999-09-0712-22/+22
* Patch from Tony R. Ambardar <tonya@ece.ubc.ca>:Joel Sherrill1999-08-1152-44/+4487
| | | | | | | | | | | | | | | | | | | I'm attaching a big patch for the ts_386ex BSP which adds and includes the following: 1) Conversion to ELF format + minor code cleanups + documentation. 2) An Ada95 binding to FreeBSD sockets, based on Samuel Tardieu's adasockets-0.1.3 package. This includes some sample applications. 3) Some Ada and C interfaces to add serial-port debugging to programs. Comes with examples, too; the Ada one shows how transparent adding the support can be. Note that Rosimildo sent me the original C code. The network stuff is not BSP specific, and could be added to your Ada code collection. The debugging stuff is specific to the i386. Right now, everything sits in my "tools" directory.
* Patch rtems-rc-19990709-6-diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1999-08-061-1/+1
