path: root/c/src/lib/libbsp/i386/ts_386ex/tools/debug_ada (follow)
* Patch rtems-rc-4.5.0-13-cvs.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>.Joel Sherrill2000-04-131-0/+2
| | | | adds .cvsignore.
* Patch rtems-rc-20000104-16.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-01-121-0/+16
| | | | that converts the libbsp/i386 subdirectory to full automake.
* Removed.Joel Sherrill1999-11-091-42/+0
* Patch from Tony R. Ambardar <tonya@ece.ubc.ca>:Joel Sherrill1999-08-118-0/+578
I'm attaching a big patch for the ts_386ex BSP which adds and includes the following: 1) Conversion to ELF format + minor code cleanups + documentation. 2) An Ada95 binding to FreeBSD sockets, based on Samuel Tardieu's adasockets-0.1.3 package. This includes some sample applications. 3) Some Ada and C interfaces to add serial-port debugging to programs. Comes with examples, too; the Ada one shows how transparent adding the support can be. Note that Rosimildo sent me the original C code. The network stuff is not BSP specific, and could be added to your Ada code collection. The debugging stuff is specific to the i386. Right now, everything sits in my "tools" directory.
