network/Makefile.am, startup/Makefile.am, timer/Makefile.am,
wrapup/Makefile.am. Use automake compilation rules.
* clock/Makefile.am, console/Makefile.am, network/Makefile.am,
startup/Makefile.am, timer/Makefile.am, wrapup/Makefile.am: Remove.
* network/Makefile.am: Cosmetics.
* clock/ckinit.c, clock/rtc.c, console/console.c, include/bsp.h,
include/coverhd.h, network/ne2000.c, start/80386ex.h,
start/80386ex.inc, start/macros.inc, start/start.S,
startup/bspstart.c, startup/linkcmds, startup/setvec.c,
timer/timer.c, timer/timerisr.S, tools/debug_ada/init.c,
tools/debug_c/init.c, tools/debug_c/serial_gdb.c,
tools/debug_c/system.h, tools/network_ada/listener/init.c,
tools/network_ada/tcprelay/init.c, tools/ts_1325_ada/init.c: URL for
license changed.
* network/Makefile.am: Use .$(OBJEXT) instead of .o.
converted to automake.
that converts the libbsp/i386 subdirectory to full automake.
that converts the i386 directory to automake.
NOTE: Ralf is unable to build any i386 BSPs. This was true before and
after this patch and appears (to Joel) to be a tool issue unrelated since
others can build i386 BSPs.
dependencies of "Makefile".
--enable-maintainer-mode.
University of British Columbia. The BSP is for:
Yes, this is the "entry model" of a series of boards from Technologic
Systems. Costs <$200 I believe. They have a WWW page at www.t-systems.com.
I am letting them know about the availability of this BSP too.
