* startup/Makefile.am: Added idt.c since it has been moved libcpu/i386
to libbsp/i386/shared/irq.
* startup/linkcmds: Added lines so DWARF debug information
would be available. Otherwise gdb complains that the offsets
for the debug info are incorrect and doesn't load the files.
* start/Makefile.am: Remove AM_CPPFLAGS and GAS_CODE16 conditional.
* startup/Makefile.am: Cleanup comments.
* clock/Makefile.am, console/Makefile.am, network/Makefile.am,
converted to automake.
that converts the libbsp/i386 subdirectory to full automake.
that converts the i386 directory to automake.
NOTE: Ralf is unable to build any i386 BSPs. This was true before and
after this patch and appears (to Joel) to be a tool issue unrelated since
others can build i386 BSPs.
I'm attaching a big patch for the ts_386ex BSP which adds and includes
the following:
1) Conversion to ELF format + minor code cleanups + documentation.
2) An Ada95 binding to FreeBSD sockets, based on Samuel Tardieu's
adasockets-0.1.3 package. This includes some sample applications.
3) Some Ada and C interfaces to add serial-port debugging to
programs. Comes with examples, too; the Ada one shows how
transparent adding the support can be. Note that Rosimildo sent me
the original C code.
The network stuff is not BSP specific, and could be added to your Ada
code collection. The debugging stuff is specific to the i386. Right
now, everything sits in my "tools" directory.
CHANGES
autoconf check
autoconf check
$(prefix)/<bsp>/make/bsp.cfg
compatible.
Makefile.ins
dependencies of "Makefile".
--enable-maintainer-mode.
ncurses, and zlib for RTEMS.
link even if they do not actually support Ada interrupts.
University of British Columbia. The BSP is for:
Yes, this is the "entry model" of a series of boards from Technologic
Systems. Costs <$200 I believe. They have a WWW page at www.t-systems.com.
I am letting them know about the availability of this BSP too.
