* configure.ac: Remove explicit ampolish3 support (now in
RTEMS_BSP_CONFIGURE).
* configure.ac: Add ampolish3 support.
* Makefile.am: Add preinstall.am.
network/Makefile.am, startup/Makefile.am, timer/Makefile.am,
wrapup/Makefile.am. Use automake compilation rules.
* clock/Makefile.am, console/Makefile.am, network/Makefile.am,
startup/Makefile.am, timer/Makefile.am, wrapup/Makefile.am: Remove.
* configure.ac: Add nostdinc to AUTOMAKE_OPTIONS.
Add RTEMS_PROG_CCAS.
* start/Makefile.am: Remove.
* Makefile.am: Merge-in start/Makefile.am.
Reflect changes to bsp.am.
* configure.ac: Remove duplicate timer/Makefile in AC_CONFIG_FILES.
* configure.ac: Remove stray ';', PR 139.
* configure.ac: Add RTEMS_BSPOPTS_*(LOAD_RTC_AT_START),
RTEMS_BSPOPTS_*(BSP_DEBUG), RTEMS_BSPOPTS_*(UARTDEBUG),
remove RTEMS_OUTPUT_BUILD_SUBDIRS.
* configure.in: Remove.
