path: root/c/src/lib/libbsp/i386/shared/pci (follow)
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | This patch is the most scary of all proposals I've been mailing to you this week until now. It consists of 3 parts: 1. a patch 2. a perl script (acpolish) 3. a shell script wrapper to invoke the perl-script. The perl-script reads in each Makefile.in and modifies them ("polishes/beautifies" them :-). These modifications are not easy to describe: Basically, it hard-codes some automake Makefile-variables and rules into RTEMS autoconf-Makefile.ins (Note: autoconf vs. automake!!) and converts some settings/variables to configure scripts' requirements (Yes, plural). E.g. it adds the automake standard variables $top_builddir and $subdir, adds dependency rules for automatic re-generation of Makefiles from Makefile.in, adds support variables for relative paths to multiple configure scripts etc. The patch is a one-line patch to enable the support of the new features added by acpolish. The shell script is a wrapper which pokes around inside of the source tree for Makefile.ins and invokes acpolish on all autoconf-Makefile.ins. acpolish is designed to be able to run several times on the same Makefile.in and may once become a more general tool to convert RTEMS Makefile.in to automake. Therefore, I'd like to keep it inside of source tree. (e.g. as contrib/acpolish or c/update-tools/acpolish). However, it doesn't make sense to export it outside of RTEMS. To apply this: cd <source-tree> patch -p1 -E < <path-to-patch>/rtems-rc-19990318-1.diff tar xzvf <path-to>/rtems-rc-polish.tar.gz ./rtems-polish.sh ./autogen Note: The path contrib/acpolish is hard-coded into rtems-polish.sh, if you decide to put it in an alternative place, please modify rtems-polish.sh to reflect this change. Later: cvs rm make/rtems.cfg (It isn't used anymore) cvs add contrib cvs add contrib/acpolish cvs commit I've tested this intensively, but naturally I can't exclude bugs. Ralf. PS.: Most probably, this is the last "Towards automake" patch. The next one probably will be a real automake patch.
* Part of the automake VI patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de>:Joel Sherrill1999-02-181-1/+3
* Large patch from Erik Ivanenko <erik.ivanenko@utoronto.ca> whichJoel Sherrill1998-10-053-0/+577
moves pieces of the pc386 bsp up to a shared level for all i386 BSPs and modifies the i386ex BSP to use those shared pieces. Serial remote debugging is included for both targets. Erik's notes: There are several workarounds in it: 1) #define NEXT_GAS is hardcoded in pc386/start/start.s 2) #define NEXT_GAS is hardcoded in i386ex/start/start.s 3) #define NEW_GAS is hardcoded in pc386/start16.s 4) #undef __assert and redeclare _assert hardcoded in console.c for both pc386 and i386ex due to my egcs1.1b ~ newlib problem. Should have modified t-rtems.cfg ( no time ) I've tested pc386 with both video and serial consoles and GDB remote. All work fine, except that GDB acts weird. ( re: other posting) I hope this will work for you. It took quite some time to locate the autoconf error. The remainder was just grunt work. Unfortunately, I think I've unwound the removal of the IBMPCInitVideo stuff. Sorry. I REALLY can't spend more time... I've been at this conversion to 4.0 locally and updating the release since Sept. 8th, and have yet to compile my network driver.... This is as much as I can do right now. I look forward to the next patch to really test i368ex. I did make sure that the sample tests worked for pc386.
