* 3c509/Makefile.am: Remove AUTOMAKE_OPTIONS.
* ne2000/Makefile.am: Remove AUTOMAKE_OPTIONS.
* wd8003/Makefile.am: Remove AUTOMAKE_OPTIONS.
* PR139
* configure.ac: Remove stray ';', breaks building with automake-1.6.
* include/bsp.h: Include rtems/bspIo.h instead of bspIo.h.
* Makefile.am: Made to compile again.
* console/inch.c: Fixed typo.
* configure.in: Remove.
* console/Makefile.am: Use 'PREINSTALL_FILES ='.
* Makefile.am: Use 'TMPINSTALL_FILES ='.
* console/Makefile.am: Remove RTEMS_H_FILES.
* start/start16.S: include <bspopts.h> to get NEW_GAS.
* 3c509/Makefile.am: Dito.
* console/Makefile.am: Dito.
* ne2000/ne2000.c: Remove #define __INSIDE_RTEMS_BSD_TCPIP_STACK__.
* console/vt.c: Added include of <rtems.h> so _CPU_ISR_disable
would be visible.
would be visible.
* console/inch.c, console/keyboard.c, console/pc_keyb.c,
console/vt.c, include/bsp.h: Correct incorrect interrupt level
handling in new keyboard management code. Correct
BSP_poll_char initialization routine.
* start/start.S, startup/bspstart.c: Correct when the video is
initialized.
* timer/timer.c (Calibrate_1ms_loop): Address problem where this
did not work correctly on all PC speeds. The new calibrate routine
has been tested on Pentium 166, pentium II 200, pentium III
300 Mhz and does work as expected.
* pc386/console/console.c, pc386/console/serial_mouse.c,
pc386/console/vgainit.c, shared/comm/tty_drv.c: Remove warnings.
* startup/sbrk.c: Removed. Redundant with shared version.
* configure.in, Makefile.am: ACLOCAL_AMFLAGS= -I $(RTEMS_TOPdir)/macros.
* console/serial_mouse.c: Fixed typos introduced by removal of CR/LF.
* console/serial_mouse.c: Added support for changing serial parameters.
* include/wd80x3.h: Added file header and logic to prevent multiple
inclusions of this file.
* wd8003/wd8003.c: Corrected attach to include "int attach" parameter.
* include/bsp.h: Cleaned up network driver name and attach defines.
* ne2000/ne2000.c: Fix some errors in the driver.
1. There was no sufficient check of data in ethernet header.
The code in ne_rx_daemon() was:
inport_word (dport, len);
len -= 4;
if (len > 0)
ne_read_data (sc, startaddr, len, p);
Unfortunately, sometimes my NIC gave me too big len value,
the result was memory override. To fix this, I added ethernet
header data checking.
2. The way overrides were serviced was not good. It was complex
but sometimes did not provide reliable continuing of NIC working.
I had the situation of an endless loop in ne_check_status()
after override processing.
3. There was conceptual error of porting. The old method of
overrides curing was ported from the OS-s, where override-processing
did start immediately. But RTEMS-version uses events, and cleaning
of the overrides can start later.
I selected the way of ne2000 programming that is used
in freebsd kernel (v4.0).
Because of both problems, incorrect data in header of raw packet
and receiver override, it went through ne_reset() and fully
reset the ne2000.
So, in summary
- added detecting of the incorrect data in ethernet header;
- replaced handling of receiver overrides with new scheme,
via resetting of NIC, this method is used also in case of
invalid header detecting.
* console/console.c, console/serial_mouse.c, include/bsp.h:
Add the ability to set parity, number of data bits and
number of stop bits to the existing i386 serial drivers.
* startup/Makefile.am: Added idt.c since it has been moved libcpu/i386
to libbsp/i386/shared/irq.
* startup/linkcmds: Added lines so DWARF debug information
would be available. Otherwise gdb complains that the offsets
for the debug info are incorrect and doesn't load the files.
* start/Makefile.am: Remove AM_CPPFLAGS and GAS_CODE16 conditional.
* 3c509/Makefile.am, clock/Makefile.am, console/Makefile.am,
ne2000/Makefile.am, start/Makefile.am, startup/Makefile.am,
timer/Makefile.am, wd8003/Makefile.am, wrapup/Makefile.am: Include
compile.am
* console/keyboard.h: Changed numerous routines from extern inline
to static inline.
* Major rework of the "/dev/console" driver.
* Added termios support for stdin ( keyboard ).
* Added ioctls() to support modes similar to Linux( XLATE,
RAW, MEDIUMRAW ).
* Added Keyboard mapping and handling of the keyboard's leds.
* Added Micro FrameBuffer driver ( "/dev/fb0" ) for bare VGA
controller ( 16 colors ).
* Added PS/2 and Serial mouse support for PC386 BSP.
* console/defkeymap.c: New file.
* console/fb_vga.c: New file.
* console/fb_vga.h: New file.
* console/i386kbd.h: New file.
* console/kd.h: New file.
* console/keyboard.c: New file.
* console/keyboard.h: New file.
* console/mouse_parser.c: New file.
* console/mouse_parser.h: New file.
* console/pc_keyb.c: New file.
* console/ps2_drv.h: New file.
* console/ps2_mouse.c: New file.
* console/ps2_mouse.h: New file.
* console/serial_mouse.c: New file.
* console/serial_mouse.h: New file.
* console/vgainit.c: New file.
* console/vt.c: New file.
* console/Makefile.am: Reflect new files.
* console/console.c, console/inch.c, console/outch.c: Console
functionality modifications.
* startup/Makefile.am: Pick up tty_drv.c and gdb_glue.c
location in libc.
that contains:
* Removes MKLIB
handling)
converted to automake.
that contains:
regarded as bugs).
now works).
* removes libbsp/bare/wrapup
* Further cleanups
to make the BSP boot on netboot.
BSP alias on the tools.
