You will find enclosed a patch which contains, for Intel PC386 target :
- an Ethernet driver for DEC21140 device based boards.
- a simple cache management with paging mechanism.
undefined problem.
compiler dependent flag in a Makefile.
Some Makefile.ins depend on gcc by hard-coded gcc-specific compiler
flags:
-g added to CFLAGS /LDFLAGS in
> find . -name Makefile.in -exec grep -l ' \-g' {} \;
./c/src/lib/libbsp/i386/i386ex/startup/Makefile.in
./c/src/lib/libbsp/i386/pc386/tools/Makefile.in
-Wall added CFLAGS in
> find . -name Makefile.in -exec grep -l ' \-Wall' {} \;
./c/src/exec/score/tools/sh/Makefile.in
Both -g and -Wall should not be used in any Makefile.in (Yes, I know,
tools/sh/Makefile.in was written by me :-).
I'd like to propose to remove these flags from the files mentioned
above.
Corsepius <corsepiu@faw.uni-ulm.de>.
I noticed that in the 4.0.0-beta4a tar file, the file
c/src/lib/libbsp/i386/pc386/startup/linkcmds
was changed so that it no longer handles the .gnu.linkonce.r*
sections. The appended patch was applied to the file. I'm not sure
why. I think this patch should probably be backed out, although it's
not critical for the release.
<raguet@crf.canon.fr>.
now installed from the shared directory.
information to this file to be more like the gen68360.
moves pieces of the pc386 bsp up to a shared level for all i386 BSPs
and modifies the i386ex BSP to use those shared pieces. Serial remote
debugging is included for both targets. Erik's notes:
There are several workarounds in it:
1) #define NEXT_GAS is hardcoded in pc386/start/start.s
2) #define NEXT_GAS is hardcoded in i386ex/start/start.s
3) #define NEW_GAS is hardcoded in pc386/start16.s
4) #undef __assert and redeclare _assert hardcoded in console.c for
both pc386 and i386ex due to my egcs1.1b ~ newlib problem. Should have
modified t-rtems.cfg ( no time )
I've tested pc386 with both video and serial consoles and GDB remote.
All work fine, except that GDB acts weird. ( re: other posting)
I hope this will work for you. It took quite some time to locate the
autoconf error. The remainder was just grunt work.
Unfortunately, I think I've unwound the removal of the IBMPCInitVideo
stuff. Sorry. I REALLY can't spend more time... I've been at this
conversion to 4.0 locally and updating the release since Sept. 8th, and
have yet to compile my network driver.... This is as much as I can do
right now.
I look forward to the next patch to really test i368ex. I did make sure
that the sample tests worked for pc386.
test were suggested by Ian Taylor <ian@airs.com> and Joel did the
hard part of putting it in aclocal and editting all the offending
Makefiles and source code which could use this feature.
The pc386 linker scripts omits .gnu.linkonce.r* sections. It's not a
big deal, but they should be treated like .rodata sections. ELF
versions of g++ generate them for static constants defined in template
classes, such as string::npos.
1. Finally fixes raw interrupts for pc386
2. Makes some minor cleanup in console and startup
3. Makes rtems_termios_dequeue_characters() to return count of
outstanding chars - it allows to simplify console isrs a little
bit.
4. pc386 uart modified to be friendlier to termios parameter changes,
to have minor performance improvement and to take advantage of
of above termios modification.
I am sending you patch which was lost. As far as I remember there
were minor patches on top of it, either by Eric Valette or
by Eric Norum or by both.
Here are patches that bring 980911 back to what I think is a correct
version of raw IDT management as well as a correct initialisation
of video console and rtems managed interrupts.
Compiled and booted without problem. However console was set on COM2.
At least for 4.0 it should be video :-)
in a previous patch. Comments from Eric:
patch_com2 was before your own fixes of raw IDT vector management
routine.
It mainly use human readable constants for the serial line driver code
+ the patch you gave me for com2 write routine.
I applied your patch for raw IDT mngt on top of that. Then made minor
cleaning in patch_idt_mngt. I hope this helps.
After some good comments from Eric Norum [thanks, Eric !],
I have added some modifications to my previous driver patch :
- wait for transmitter ready before sending a packet,
- new delay management in case of ring-overwritting.
I have reworked the ethernet driver for the BSP pc386 and
here is the patch to apply.
Eric> NB : there is still a bug on PC386 serial line : exit does not
Eric> flush the remaining output queue. As this is not a bug in the
Eric> driver itself but somewhere in PC386 initialization/termios
Eric> relationship it will be part of another patch.
Eric> NB2 : As Emmanuel excerced the exception hanlder code, while
Eric> porting the SMC driver to the new BSD stack, we found a bug
Eric> in the exception handler : it shall not delete the current
Eric> thread in case we are running at interrupt level. This will
Eric> be part of another patch...
So here is the patch. This patch fixes the two problems mentionned above
+ it use vpath mechanism intead of copying the irq related files in
the right directory. This avoid to compile them each time and is
more homogenous with other Makefiles.
Here is a brief description of the attached patch :
1) There was a bug in the code for the COM2 serial line driver. Aleksey
gave me a fix that fixes the driver code itself. I would like to thank
him again publicly,
2) I introduced constants in the serial driver code because I had a hard
time reading the meanning of hexadecimal values in the NS data book :)
3)You can now mix printk and printf on serial line (tested on COM2).
There is a #ifdef PRINTK_ON_SERIAL in console.c that enables to have
printk on console while printf on serial line,
4) Removed call to displayCpuInfo because anyway if was at the wrong
place for serial line console (too early). It can anyway be called at
application level,
5) The original printk was unable to display negative integer values
and was also recursive. It now works corectly,
All the modifications have been tested here on the COM2 port from
a PC running RTEMS to a PC running linux,
NB : there is still a bug on PC386 serial line : exit does not flush the
remaining output queue. As this is not a bug in the driver itself but
somewhere in PC386 initialization/termios relationship it will be part
of another patch.
NB2 : As Emmanuel excerced the exception hanlder code, while porting the
SMC driver to the new BSD stack, we found a bug in the exception
handler : it shall not delete the current thread in case we are running
at interrupt level. This will be part of another patch...
Celso Labinaz <labinaz@tin.it> pointed to me thatthe console on serial
line was not working. After spending quite a time to find the right
cable and software, I confirm this.
I'm going to debug this in the next days because I want to use the
serial line for debugging. In the meantime, in order to be sure that
this was a driver initialization/bug, I made printk work on the serial
line in order to be sure the receiver part and configuration was OK.
Here is the for printk on serial line. BTW, does anyone else use the
serial line facilities for PC? printf seems to output nothing (hello.exe
output everything that has a printk but application printf seems to be
broken).
Here is a patch that enables to catch exception
and get message before crashing RTEMS :)
It should be generic to any Intel port although enabled
only for pc386 BSP...
[Joel] I fixed the bug I introduced in irq_asm.s...
This patch has same changes as one I sent to you earlier plus
it fixes _heap_size problem for pc386 we had discussed earlier.
Now, _heap_size is defined and set to 0 in pc386/startup/bspstart.c
It can be patched to desireable value in binary image. If it is
left unpatched, then startup code will determine size of memory
(on the assumption that at least 2MB are present) and use
max possible heap.
It fixes netboot build problem, KA9Q configuration
for pc386, some compiler wardning, it also removed some stuff
ifdef'ed with '#if 0'.
inline with the new IRQ structure.
Enabled on the pc386.
<raguet@crf.canon.fr> to make their patches work together.
Here is a patch for KA9Q stack.
This patch contains an Ethernet Driver for Western Digital,
some fixes for the UDP and TCP protocols (for endian conversion)
and some little programs which allow the test of UDP and TCP
sockets via Ethernet.
I have tested that on an Intel machine. If someone can test it
on a big-endian machine, ...
of theses targets...
c/src/lib/libbsp/i386/pc386/console/console.c
__assert() modified so it prints on selected console instead of
PC console
c/src/lib/libbsp/i386/pc386/console/inch.c
inch_sleep() modified, so it does not depend upon tmacros.h
c/src/lib/libbsp/i386/pc386/pc386dev/GDB.HOWTO
description updated
c/src/lib/libbsp/i386/pc386/startup/exit.c
last output before call to exit() will be printed properly on
serial console
c/src/lib/libbsp/i386/pc386/startup/irq.c
re-submitted bug fix for problem in irqs over 7.
<qqi@world.std.com>). Unfortunately after merging these,
the pc386 will not boot using grub for for. It still does not
work using netboot for me. Here is his summary of changes:
rtems/c/src/lib/libbsp/i386/pc386/Makefile.in
Added support for new sub-directory
rtems/c/src/lib/libbsp/i386/pc386/bsp_specs
Made possible to build COFF image
rtems/c/src/lib/libbsp/i386/pc386/console/console.c
Added support for serial consoles, selectable by patching
binary image, added __assert(), use _IBMPC_inch_sleep()
instaed of _IMBPC_inch()
rtems/c/src/lib/libbsp/i386/pc386/console/inch.c
Added _IMBPC_inch_sleep()
rtems/c/src/lib/libbsp/i386/pc386/console/outch.c
Oops - just formatting
rtems/c/src/lib/libbsp/i386/pc386/include/Makefile.in
Added support for new files
rtems/c/src/lib/libbsp/i386/pc386/include/bsp.h
Added support for new features
rtems/c/src/lib/libbsp/i386/pc386/include/pc386uart.h
New file: definitions for serial ports
rtems/c/src/lib/libbsp/i386/pc386/include/pcibios.h
New file: definitions for PCI BIOS
rtems/c/src/lib/libbsp/i386/pc386/pc386dev/Makefile.in
New file: makefile in new directory
rtems/c/src/lib/libbsp/i386/pc386/pc386dev/i386-stub-glue.c
New file: i386-stub interface
rtems/c/src/lib/libbsp/i386/pc386/pc386dev/i386-stub.c
New file: i386-stub itself
rtems/c/src/lib/libbsp/i386/pc386/pc386dev/pc386uart.c
New file: serial ports
rtems/c/src/lib/libbsp/i386/pc386/pc386dev/pcibios.c
New file: PCI BIOS support
rtems/c/src/lib/libbsp/i386/pc386/start/start.s
Commented out DEBUG_EARLY stuff, everything is working fine
rtems/c/src/lib/libbsp/i386/pc386/start/start16.s
Cleaned up
rtems/c/src/lib/libbsp/i386/pc386/startup/bspstart.c
Added call to console_resereve_resources
rtems/c/src/lib/libbsp/i386/pc386/startup/exit.c
rtems/c/src/lib/libbsp/i386/pc386/startup/ldsegs.s
Fixed typo in comments
rtems/c/src/lib/libbsp/i386/pc386/tools/Makefile.in
Changed to reflect cnages in code
rtems/c/src/lib/libbsp/i386/pc386/tools/bin2boot.c
Trivialized, problem - I do not know how to make patch
remove obsolete files - there are a lot of them there
rtems/c/src/lib/libbsp/i386/pc386/tools/binpatch.c
New file: utility to do binary patches
rtems/c/src/lib/libbsp/i386/pc386/wrapup/Makefile.in
Added support for new directory
rtems/make/custom/pc386.cfg
Add COFF image building
all the targets:
breaking CXX support.
handling.
after minor changes.)
insecure about.
external packages.
may be broken).
disturb now.
--enable-* flags).
--enable-gcc28 are given.
mvme162.cfg-bug.
Here are his comments:
I removed all unnecessary stuff from start16.s - setting idt and
setting 16-bit stack using .code32 istructions.
to fix start16.s. It does not work locally.
versions of these utilities with C implementations.
+ DEBUG_EARLY_START re-added (Eric Valette)
+ segment register initialization (Aleksey/Quality Quorum)
+ heap size use correction
+ more debug printk's
+ increased heap size.
Now works with grub boot on all systems I have access to including
desktops and a laptop. This is with the i386-rtems tools.
Neither i386-rtemself nor netboot produces a working executable.
