Update #3285.
Update #3285.
Update #3285.
Update #3285.
system. Since all content of
makes no sense to keep it.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #2408.
Update #3285.
Update #3285.
Update #3387.
Update #3285.
Update #3285.
Update #3285.
This was used by the not supported "make dist".
Update #3285.
Update #3285.
Update #3285.
upgrade to that version.
Close #3387.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
With HAS_SMP set, we have:
libbsp_a_LIBADD += appstart.$(OBJEXT)
When trying to build appstart.o, however, we link start.o with appcpustart.o
through the linkcmds script, which leaves several symbols unresolved, and
without the "-r" (or -i) flag, this throws undefined reference errors.
This change requires us to re-run the ./bootstrap script to regenerate
Makefile.in, and therefore the Makefile for the particular BSP as well.
Complete log of errors available here:
https://gist.github.com/AmaanC/d40bd7393dca1f82965938275845b7f9
Updates #3331
* bsps/shared/cache
Update #3285.
line option.
may suppress warnings.
erc32, imx, qoriq, etc.
* cpukit/include
* cpukit/libnetworking
* bsps/include
* bsps/@RTEMS_CPU@/include
order.
Update #3254.
This header is used also by the motorola_powerpc BSP.
Update #3254.
Update #3254.
The name suggests that this is a private implementation header file.
Update #3254.
Update #3254.
EXTRA_DIST += foobar
in fragments.
Update #3254.
Update #3254.
If this has any issues, check that the change in linking the
16-bit startup code in Makefile.am generates the same code.
This was odd code and didn't need the RTEMS linkcmds anyway.
Updates #3520.
Updates #3520.
Patch was not intended to be pushed yet.
Updates #3520.
Done:
arm
bfin
epiphany
i386
lm32
m32c
mips
moxie
nios2
or1k
powerpc
riscv
sh
sparc
sparc64
v850
To do:
m68k
Differences noted:
+ endfile was sometimes before startfile
+ endfile sometimes was hard-coded and did not have -qrtems version
+ Should -e XXX (e.g. entry point) be in linkcmds?
+ Should -u XXX (e.g. undefined symbols) be in linkcmds?
+ Typos: Odd spacing, "old_endfiles" typo, and *(old_endfiles) (not %)
+ nios2: Referenced crtnn.o not crtn.o (error)
Need to revisit:
+ m32c, moxie, sparc64 includes !nostdlib which is not used elsewhere
+ sh has -EL/-EB mapping. Why needed?
+ sparc64 didn't include crti.o/crtn.o but it is part of toolset
+ v850 uses something like this for link and end_file:
"%{qrtems: %(old_link)}"
This means that these are unnecessary. Try this on all.
+ mips uses old_link all the time also.
+ arm/tms750 adds -EB.
+ powerpc: Why do we have rtems_crt* and not use something from GCC?
Updates #3520.
Updates #3250.
maintain.
Update #3254.
