* start/Makefile.am: Remove AM_CPPFLAGS and GAS_CODE16 conditional.
* 3c509/Makefile.am, clock/Makefile.am, console/Makefile.am,
ne2000/Makefile.am, start/Makefile.am, startup/Makefile.am,
timer/Makefile.am, wd8003/Makefile.am, wrapup/Makefile.am: Include
compile.am
* console/keyboard.h: Changed numerous routines from extern inline
to static inline.
* Major rework of the "/dev/console" driver.
* Added termios support for stdin ( keyboard ).
* Added ioctls() to support modes similar to Linux( XLATE,
RAW, MEDIUMRAW ).
* Added Keyboard mapping and handling of the keyboard's leds.
* Added Micro FrameBuffer driver ( "/dev/fb0" ) for bare VGA
controller ( 16 colors ).
* Added PS/2 and Serial mouse support for PC386 BSP.
* console/defkeymap.c: New file.
* console/fb_vga.c: New file.
* console/fb_vga.h: New file.
* console/i386kbd.h: New file.
* console/kd.h: New file.
* console/keyboard.c: New file.
* console/keyboard.h: New file.
* console/mouse_parser.c: New file.
* console/mouse_parser.h: New file.
* console/pc_keyb.c: New file.
* console/ps2_drv.h: New file.
* console/ps2_mouse.c: New file.
* console/ps2_mouse.h: New file.
* console/serial_mouse.c: New file.
* console/serial_mouse.h: New file.
* console/vgainit.c: New file.
* console/vt.c: New file.
* console/Makefile.am: Reflect new files.
* console/console.c, console/inch.c, console/outch.c: Console
functionality modifications.
* startup/Makefile.am: Pick up tty_drv.c and gdb_glue.c
location in libc.
that contains:
* Removes MKLIB
handling)
converted to automake.
that contains:
regarded as bugs).
now works).
* removes libbsp/bare/wrapup
* Further cleanups
to make the BSP boot on netboot.
BSP alias on the tools.
that converts the libbsp/i386 subdirectory to full automake.
that fixes the following problems:
1. Removing bogus ';' in some configure.in (cosmetical fix)
2. Moves GAS_CODE16 checks to libbsp/i386/*/configure.in (essential fix)
#2 was responsible for the gcc/binutils-2.9.5 choking while building for
the pc386.
registers.
that converts the i386 directory to automake.
NOTE: Ralf is unable to build any i386 BSPs. This was true before and
after this patch and appears (to Joel) to be a tool issue unrelated since
others can build i386 BSPs.
problems:
- unclosed comment in pc386/start/start16.S
- bad #endif in pc386/startup/ldseg.S
to added the bin2boot_SOURCES warning.
delay loop in this BSP. Here is his response to a question about
the patch:
Yes, or that other machine has a different chipset with different
timing requirements on enabling Gate 20. I am strongly suspecting
that it may some how related to the video card I am using (on my
old P-75 target it was plain PCI VGA, on my new one it is Diamond Stealth
3D 2000).
dec21140 drivers from the i386/pc386 and powerpc/mcp750 (all Motorola
PowerPC boards) and move the network driver to libchip. This driver
should work on all PCI based uses of this chip.
to consistently use $(EXEEXT).
*.cfg files.
dependencies
automake and RTEMS make rules
convention)
performs automatically.
WARNING:
Makefile.ams.
increase ease of application configuration of the pc386 BSP. This
patch allows switching the printk console to a serial port and
overriding bsp_start by making it a weak alias.
the receive buffer size was 16 bytes too small.
proper Multiboot signature to pc386 BSP. This enables Grub to
recognize the image.
mkdir c/src/librpc
mkdir c/src/librpc/src
mkdir c/src/librpc/include
rm -rf c/src/lib/librpc
rm -rf c/src/lib/include/rpc
in the required order .
# make[5]: Entering directory
# mips64orion-rtems-gcc -v
# mips64orion-rtems-ld -v
initialization typo and make i8259s_cache only accessed from C.
